[blockMesh] Problems of mutiple regions
Old   February 7, 2008, 14:23
Default Problems of mutiple regions
feng wang
fw407 is on a distinguished road
Hi, guys
I want to create a third region in a Fluid-Structure case, but came into problems.
When I try to make a symbolic link for the regions, the first two regions is going well, but when I try to make a symbolic link for the third region(which I want to add), the symbolic link is not working well.and when I try:
blockMesh . icoStructFoamTest_multipe_region
I end up with errors:
fw407@fw407-laptop:~$ ln -s /home/fw407/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam/icoStructFoamTest_mul tipe_region/constant/region3/polyMesh/ /home/fw407/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam/icoStructFoamTest_mul tipe_region/constant/polyMesh
fw407@fw407-laptop:~$ cd /home/fw407/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam
fw407@fw407-laptop:~/OpenFOAM/fw407-1.3/run/tutorials/icoStructFoam$ blockMesh . icoStructFoamTest_multipe_region
Reading block mesh description dictionary
--> FOAM FATAL ERROR : Cannot find mesh description file
"constant/polyMesh/blockMeshDict" or
"constant/polyMesh/meshDescription" or
"constant/mesh/meshDescription"
From function blockMesh
in file genBlockMesh.C at line 102.
FOAM exiting
Could anyone tell me how to solve it?
All the best
Feng
fw407 is offline   Reply With Quote
Old   February 7, 2008, 14:56
Default Is there a file icoStructFoam
Assistant Moderator
Bernhard Gschaider
Is there a file icoStructFoamTest_multipe_region/constant/region3/polyMesh/blockMeshDict ?
Did you remove the symbolic link from the previous regions?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 8, 2008, 07:54
Default Hi, Bernhard There is a fil
feng wang
Hi, Bernhard
There is a file icoStructFoamTest_multipe_region/constant/region3/polyMesh/blockMeshDict
and I have removed the symbolic link before I make a new one
However, the property dialogue of the symbolic link I create for region 3 tells me it is a broken one.
By the way, do you think it has a connection with a file called tetFemSolution? because in this file, it only define something like:
object tetFemSolution; ln -s (symbolic link for region 2)
All the best
Feng
Benchmark Problems to test a new scheme for Convection-diffusion equation alibaig1991 Main CFD Forum 1 June 16, 2018 04:30
Patankar 1980 (Diffusion Convection Problems) hhandoko System Analysis 1 January 25, 2018 07:56
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
