June 2, 2007, 16:00 |
3D Mesh question
Ryan
First off I am new to openFoam and only been working with it for about two weeks. I'm looking to import meshes from Salome and have successfully done it using unvtofoam and then autopatch to create the patches. The problem I am having is with the defaultpatch which is the internal mesh points. I'm not sure what to call them since empty causes problems because from what I gather than is used for 2D cases. Is there a utility that removes the internal mesh or is there a type to designate them to get the calculation to work? BTW I'm just trying a simple rectangle right now with an inlet and a outlet using icoFoam. Thanks
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
ICEM 2D tetra mesh question | kawamatt2 | ANSYS Meshing & Geometry | 18 | March 3, 2014 10:56 |
[ANSYS Meshing] Question about mesh generation learning | lnk | ANSYS Meshing & Geometry | 2 | July 7, 2012 06:45 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
