[Commercial meshers] Import error Gambit msh file with Cell Type 7 polyhedral cells
Old   May 31, 2007, 14:21
Default Import error Gambit msh file with Cell Type 7 polyhedral cells
Philippose Rajan
philippose will become famous soon enough
Hello everyone,
After a long silence I am back :-)! A Good evening to everyone.... had been to India on holiday, and guess what... I got the opportunity to spend over half a day explaining and demonstrating OpenFOAM to the CFD group of a fairly large engineering solutions company there :-)!
Anyway.... I am currently working on validating a couple of results between OpenFOAM and Fluent.
A 3D mesh was constructed in Gambit in which the hanging nodes a "Hexcore" mesh produces were removed by converting the cells to polyhedral cells. These cells are specified in the exported file (.msh file), as cell type 7.
However, in the "fluentToFoam" convertor, there exists only cell types 0 to 6, causing the convertor to abort with the error that the cell type could not be recognised.
It would be great if someone could give me a solution / workaround or tips for getting past this error.
By the way... this type of mesh was chosen over the "hexcore" mesh, because the converter failed to import a "hexcore" mesh too. The error in this case, was, that the converter does not recognise fluent ID 59, which is the ID for "face trees".
As far as I understood, "face trees" are used to specify connectivity for hanging nodes.
Could someone help me out here?
Have a lovely day!
Philippose
philippose is offline   Reply With Quote
Old   June 1, 2007, 02:58
Default I had the same problem, but no
Francesco Del Citto
fra76 is on a distinguished road
I had the same problem, but noone gave me an answer:
http://www.cfd-online.com/OpenFOAM_D...tml?1172138522
Bye
Francesco
fra76 is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 02:54
