February 19, 2010, 07:35 |
2D Mesh-Refinement
Michael Harrer
Hello foamers,
Im working with the dynamic mesh refinement known from i.e. the dambreak-case (dynamicRefineFvMesh.C) and everything works fine as long as i create a 3D-case. I want to simulate a 2D-case with "empty"-type boundaries, but when i do so it wont work, because the count of cells is not equal to the count of faces (seems to be the restriction for 2D-cases). So i would like to refine the cells just in the xy-plane to solve my problem. Is there a simple method to do so? Best regards, Michael |
May 31, 2010, 03:08 |
Victor Fleischer
Hallo at all,
I am interested in the same problem. I would like to use dynamicRefineFvMesh to increase the mesh-refinement at the detonation front in detonation simulations. In order to reduce the number of cells i'd like to refine the mesh only in two directions (as it is possible in the static version refineMesh). I know already that the refinement is done by hexRef8.c, but i do not really know what is going on there. Does somebody have experiences with this or any idea how to solve this problem? Thanks in advance! Victor |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer | Sunxing | OpenFOAM Meshing & Mesh Conversion | 9 | September 20, 2014 09:30 |
