[snappyHexMesh] Createpatch and SnappyHexMesh |
July 19, 2010, 21:52 |
Rep Power: 15 |
So I created a blockMeshDict file for a quarter cylinder and create two patches there. Then I decreased the matchTolerance in createPatchDict and turned off pointSync and combined two patches to create a cyclic patch. But when I use snappyHexMesh I get the same error I used to get using createPatch (before I turned off pointSync and decreased the matchtolerance). The error is
face 0 area does not match neighbour 200 by 44.3085%..... Im assuming a matchTolerance in snappyHexMesh would fix this but I dont see that keyword and when i try to run snappyHexMesh with the keyword it gives me the same error. Anyone encounter this before or better yet solved it? Update - the problem above was solved by redefing the vertices so that the face areas are the same. But now when I run snappyHexMesh it gives me the following error - Faces do not seem to be correct across coupled boundaries Anyone know why this is? Thanks! Last edited by hm86; July 20, 2010 at 17:15. |
February 3, 2011, 09:50 |
Same Error
Jerry
Rep Power: 15 |
Hi hm86,
I'm encountering exactly the same problem as you had. And was wondering whether you found a fix for yours? Thanks! |
There is a bug in createPatch? | feno102 | OpenFOAM Pre-Processing | 6 | November 1, 2017 02:24 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[mesh manipulation] cyclic patches with different no. of faces - snappyHexMesh - createPatch | KYPCK444 | OpenFOAM Meshing & Mesh Conversion | 1 | September 27, 2013 07:13 |
Scaling and SnappyHexMesh | kingmaker | OpenFOAM Pre-Processing | 3 | July 15, 2013 09:05 |
[snappyHexMesh] snappyHexMesh createPatch cellLevel | ulli | OpenFOAM Meshing & Mesh Conversion | 1 | October 1, 2009 10:23 |
