[snappyHexMesh] Createpatch and SnappyHexMesh
Old   July 19, 2010, 21:52
Default Createpatch and SnappyHexMesh
hm86 is on a distinguished road
So I created a blockMeshDict file for a quarter cylinder and create two patches there. Then I decreased the matchTolerance in createPatchDict and turned off pointSync and combined two patches to create a cyclic patch. But when I use snappyHexMesh I get the same error I used to get using createPatch (before I turned off pointSync and decreased the matchtolerance). The error is
face 0 area does not match neighbour 200 by 44.3085%.....
Im assuming a matchTolerance in snappyHexMesh would fix this but I dont see that keyword and when i try to run snappyHexMesh with the keyword it gives me the same error. Anyone encounter this before or better yet solved it?
Update - the problem above was solved by redefing the vertices so that the face areas are the same. But now when I run snappyHexMesh it gives me the following error -
Faces do not seem to be correct across coupled boundaries
Anyone know why this is?
Thanks!
hm86 is offline   Reply With Quote
Old   February 3, 2011, 09:50
Default Same Error
Jerry
J.Randall is on a distinguished road
Hi hm86,
I'm encountering exactly the same problem as you had. And was wondering whether you found a fix for yours?
Thanks!
J.Randall is offline   Reply With Quote
There is a bug in createPatch? feno102 OpenFOAM Pre-Processing 6 November 1, 2017 02:24
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[mesh manipulation] cyclic patches with different no. of faces - snappyHexMesh - createPatch KYPCK444 OpenFOAM Meshing & Mesh Conversion 1 September 27, 2013 07:13
Scaling and SnappyHexMesh kingmaker OpenFOAM Pre-Processing 3 July 15, 2013 09:05
[snappyHexMesh] snappyHexMesh createPatch cellLevel ulli OpenFOAM Meshing & Mesh Conversion 1 October 1, 2009 10:23
