[snappyHexMesh] multi region
Old   August 11, 2011, 10:34
Default multi region
zurg
laplacian is on a distinguished road
Hallo everybody,
I am looking for a way to generate a 3d complex mesh starting from stl file, for chtMultiRegion OpenFOAM 1.7 solver.
sHM works well if I have only one stl file (also divided in many patches).
The problem is when I try to use chtMultiRegion, with more than one region and of complex geometry: it means not a simple box or a cylinder, but a scanned geometry of real objets.
No upgrade after this post:
So the multi region approach of snappyHexMesh can only work in block mesh like geometries…
http://www.cfd-online.com/Forums/ope...n-meshing.html
Any idea or help to skip the problem. Or someone could suggest me another open-source tool working in such case, for example "Salome"?
Many thanks
laplacian is offline   Reply With Quote
Old   July 20, 2012, 06:49
Lightbulb Open Foam 2.0
zurg
as partial solution: form OpenFOAM 2.0 it's possible generate multi domain meshes. However in chtMultiRegion solver you can't add layers , so ... for detailed mesh generation it could be better use different tools.
cht, multi body, multi regions, snappyhexmesh
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
