[snappyHexMesh] Multi Stl snappyHexMesh
Like Tree1Likes
  • 1 Post By GRAUPS
Old   July 23, 2012, 16:45
Default Multi Stl snappyHexMesh
Kalyan
kalyangoparaju is on a distinguished road
Friends,
I am trying to mesh a geometry with 3 regions ( inlet, porous and outlet). I have 3 closed stl's for all the 3 regions in the triSurface dictionary. When I write the snappyHexMeshDict ( with inspiration from the multi region meshing in chtmultiregionfoam), I define the stls as faceZone and CellZone.
When snappy runs, it detects these face zone and "walks through them" and meshes both inside and outside the pipe ( all 3 regions). When I comment out the faceZone option, it meshes only in the region where the locationInMesh is found.
After some thought, I realized that it might help making the closed surfaces which are the interfaces btween the different stls as faceZone and then let snappy just walk through them build the mesh, theoretically. Unfortunately, that doesn't happen
Is there a better way to do this. In simple words, how to mesh for an internal flow geometry with closed stls by multi region approach using snappyHexMesh.
Hope I was clear.
Kalyan
kalyangoparaju is offline   Reply With Quote
Old   November 15, 2012, 05:07
Unnikrishnan Mohankumar
unnikrsn is on a distinguished road
Dear Kalyan
I am working on the same topic to " Mesh Stl files in SnappyHexMesh to get internal faces".. if you have proceeded any further.. Kindly provide the details..
Thanks in advance.
Thanks & regards
Unnikrishnan.
unnikrsn is offline   Reply With Quote
Old   November 15, 2012, 09:16
Brock Lee
GRAUPS is on a distinguished road
I am also having the exact same issue as you Kalyan. I also posted in this thread referencing this problem.
Originally Posted by GRAUPS View Post
My case is a cylinder with an inlet region, outlet region, and porous region in the middle. I used three closed stl files to define it.
After meshing, including layer addition, I wish to be able to keep the interfaces between the meshed internal zones as faceZones, that is the main goal. However, it seems like I'm having similar issues as Kalyan had, where it is not crossing over the faceZones correctly and instead of keeping the internal mesh for internal flow and the intersections as faceZones, it meshes the outside domain and only part of the cylinder.
I also gave an example case, which you can find below, that I believe represents the problem Kalyan describes.
cylinder_cfd.zip
Does anyone have an explanation as to why what Kalyan describes is happening?
challenger likes this.
GRAUPS is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] What types of stl files are needed in snappyhexmesh? phandy OpenFOAM Meshing & Mesh Conversion 1 February 19, 2015 05:36
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Meshing & Mesh Conversion 9 April 7, 2012 08:50
[snappyHexMesh] Patch Names in STL file for snappyHexMesh Kattie OpenFOAM Meshing & Mesh Conversion 11 October 18, 2011 11:05
