[Other] accesing points of a cell in a mesh
Old   May 3, 2010, 09:05
Default accesing points of a cell in a mesh
O R
arkangel is on a distinguished road
Dear Foamer,
I hope someone can help me
I have an external solver with a structured grid, I wan to interpolate the values of this grid into a polyMesh .
1) I can create one polyMesh with the information from the structured grid
2) or I can create the polyMesh in a more standard way and just interpolate the values of each grid on each other
I want to create a Chimera Grid like library , I know how to access the Cell center but to have a complete relationship I need to know the coordinates of the cell vertices, more or less like :
forAll(mesh.C(), cellI)
forAll(mesh.cells()[cellI].points(), pointI){
Info << mesh.cells()[cellI].points()[pointI].x()<<endl;
Info<<mesh.C()[cellI].x()<<endl;
How can I write the inner forAll to get the x,y,z coordinates of all points /vertices in one cell ?
Thanks
arkangel is offline   Reply With Quote
Old   June 28, 2012, 15:43
Junpeng
rolandde is on a distinguished road
Did you figure it out? I have the same problem...
rolandde is offline   Reply With Quote
Old   October 16, 2012, 09:18
Adam
Smed is on a distinguished road
Can anyone answer this?
How do you access all of the vertices of a cell?
mesh.points()[cellI]
only returns the coordinates of a single vertex associated with that cell.
Smed is offline   Reply With Quote
Old   October 16, 2012, 12:11
Adam
This question is answered here:
http://www.cfd-online.com/Forums/ope...ize-x-y-z.html
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
