[snappyHexMesh] AMI-interface "cuts" water jet |
February 15, 2013, 07:08 |
Anon
Rep Power: 13 |
Hi!
I am working on simulating the flow in a Pelton bucket numerically, but I am having some trouble with the AMI-interface. I think this is related to the meshing in the AMI-patches, as they seem to not be perfectly circular as I want them to be. I wonder if anyone has some tricks that may help me improve the representation of the flow over the interface? The AMI-patches should be circular, but how can I refine them? My case is originally based on the propeller-tutorial, but I use the interDyMFoam-solver. The water jet is cut in the AMI-interface: AMI1: AMI2: My snappyHexMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; //Originally false // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { jetinlet.obj { type triSurfaceMesh; name jetinlet; regions { jetinlet { name jetinlet; } } } jetwalls.obj { type triSurfaceMesh; name jetwalls; regions { jetwalls { name jetwalls; } } } BBC.obj { type triSurfaceMesh; name BBC; regions { BBC { name BBC; } } } MBC.obj { type triSurfaceMesh; name MBC; regions { MBC { name MBC; } } } TBC.obj { type triSurfaceMesh; name TBC; regions { TBC { name TBC; } } } statopening.obj { type triSurfaceMesh; name statopening; regions { statopening { name statopening; } } } rotif.obj { type triSurfaceMesh; name rotif; regions { rotif { name rotif; } } } rotopen.obj { type triSurfaceMesh; name rotopen; regions { rotopen { name rotopen; } } } rotsym.obj { type triSurfaceMesh; name rotsym; regions { rotsym { name rotsym; } } } statinlet.obj { type triSurfaceMesh; name statinlet; regions { statinlet { name statinlet; } } } statsym.obj { type triSurfaceMesh; name statsym; regions { statsym { name statsym; } } } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 1000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 0; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 2; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "jetinlet.eMesh"; level 3; } { file "jetwalls.eMesh"; level 3; } { file "statopening.eMesh"; level 1; } { file "rotif.eMesh"; level 3; } { file "BBC.eMesh"; level 3; } { file "MBC.eMesh"; level 3; } { file "TBC.eMesh"; level 3; } //4 nye { file "rotopen.eMesh"; level 1; } { file "rotsym.eMesh"; level 1; } { file "statinlet.eMesh"; level 1; } { file "statsym.eMesh"; level 1; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { BBC { level (2 3); //Originally (2 3) for all buckets } MBC { level (2 3); } TBC { level (2 3); } rotif { level (2 2); cellZone rotif; faceZone rotif; cellZoneInside inside; } statopening { level (1 1); } jetinlet { level (2 3); } jetwalls { level (2 3); } //4 nye rotopen { level (1 1); } rotsym { level (2 2); } statinlet { level (1 1); } statsym { level (2 3); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { /* rotif { mode inside; levels ((1E15 3)); } statinlet { mode inside; levels ((1E15 0)); } */ MBC { mode distance; levels ((0.05 5)); } TBC { mode distance; levels ((0.05 5)); } BBC { mode distance; levels ((0.05 5)); } jetwalls { mode distance; levels ((0.01 5)); } jetinlet { mode distance; levels ((0.01 5)); } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. // locationInMesh (21 601.1 211.1); locationInMesh (-0.20545645 0.111378 0.202156456); //Originalt (0.37046464 0.111378 0.37046464) // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 5; //Originally 3 //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 4.0; // 1.0; //- Number of mesh displacement relaxation iterations. nSolveIter 20; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 6; //Originally 5 //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Do not use here since mesh resolution too low and baffles present nFeatureSnapIter 20; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { } // Expansion factor for layer mesh expansionRatio 1.0; //- Wanted thickness of final added cell layer. If multiple layers // is the // thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. finalLayerThickness 0.3; //- Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; //- If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings //- When not to extrude surface. 0 is flat surface, 90 is when two faces // make straight angle. featureAngle 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 45; //Originally 65 //- Max skewness allowed. Set to <0 to disable. maxBoundarySkewness 20; maxInternalSkewness 4; //- Max concaveness allowed. Is angle (in degrees) below which concavity // is allowed. 0 is straight face, <0 would be convex face. // Set to 180 to disable. maxConcave 80; //- Minimum pyramid volume. Is absolute volume of cell pyramid. // Set to a sensible fraction of the smallest cell volume expected. // Set to very negative number (e.g. -1E30) to disable. minVol 1e-13; //- Minimum quality of the tet formed by the face-centre // and variable base point minimum decomposition triangles and // the cell centre. This has to be a positive number for tracking // to work. Set to very negative number (e.g. -1E30) to // disable. // <0 = inside out tet, // 0 = flat tet // 1 = regular tet minTetQuality -1; // 1e-30; //- Minimum face area. Set to <0 to disable. minArea -1; //- Minimum face twist. Set to <-1 to disable. dot product of face normal //- and face centre triangles normal minTwist 0.01; //- minimum normalised cell determinant //- 1 = hex, <= 0 = folded or flattened illegal cell minDeterminant 0.001; //- minFaceWeight (0 -> 0.5) minFaceWeight 0.05; //- minVolRatio (0 -> 1) minVolRatio 0.01; //must be >0 for Fluent compatibility minTriangleTwist -1; // Advanced //- Number of error distribution iterations nSmoothScale 6; //Originally 4 //- amount to scale back displacement at error points errorReduction 0.75; // Optional : some meshing phases allow usage of relaxed rules. // See e.g. addLayersControls::nRelaxedIter. relaxed { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 45; //Originally 75 } } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name rotif; type cellSet; action new; source cylinderToCell; sourceInfo { p1 (0 0 0); p2 (0 0.13908 0); radius 0.3477; } } { name outerCells; type cellSet; action new; source cellToCell; sourceInfo { set rotif; } } { name outerCells; type cellSet; action invert; } { name rotif; type cellZoneSet; action new; source setToCellZone; sourceInfo { set rotif; } } { name rotifFace; type faceSet; action new; source cellToFace; sourceInfo { set rotif; option all; } } { name rotifFace; type faceSet; action subset; source cellToFace; sourceInfo { set outerCells; option all; } } { name rotif; type faceZoneSet; action new; source setsToFaceZone; sourceInfo { faceSet rotifFace; cellSet rotif; } } ); // ************************************************************************* // |
mapField error | rvl565 | OpenFOAM Pre-Processing | 1 | September 6, 2018 16:13 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Fluid-Solid Interface Settings for a Rotating Water Container | r.mojtaba | CFX | 4 | October 14, 2013 19:01 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
