[Other] "did not succesfully snap mesh. Giving up"
Like Tree6Likes
  • 2 Post By chegdan
  • 1 Post By chegdan
  • 1 Post By chegdan
  • 1 Post By chegdan
  • 1 Post By chegdan
Old   July 8, 2013, 13:17
Default "did not succesfully snap mesh. Giving up"
s.m
saeideh mohamadi
s.m is on a distinguished road
Hi Dear All;
i use snappyHexMesh for meshing the domain around two element airfoil.
during the running of snappyHexMesh, this message is appear that ""did not succesfully snap mesh. Giving up"" . is it related to the parameters in snapControls section of snappyHexMeshDict?
if yes, what changes should i do in my snappyHexMeshDict that i have attached in the following?
thank you
s.m is offline   Reply With Quote
Old   July 8, 2013, 15:00
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I would make your base mesh smaller (i.e. change your blockMeshDict to have more subdivisions), decrease your levels on your edges from 6 7 to 5 6 or lower depending on your base mesh sizing and change
    tolerance 1.0;
    nSolveIter 300;
in snapControls. A lot of errors with SHM are resolved by changing your base mesh sizing.
s.m and MtnRunBeachBum like this.
Last edited by chegdan; July 8, 2013 at 15:55. Reason: i noticed you were actually using 2.2.x
chegdan is offline   Reply With Quote
Old   July 9, 2013, 02:28
s.m
saeideh mohamadi
    tolerance 1.0;
    nSolveIter 300;
Hi Dear chegdan,
i am using the OF 2.2.0. this is my blockMeshDict, would you please look at it and tell me is it necessary to increase the subdivisions?
Old   July 9, 2013, 10:39
Daniel P. Combest
The closer you make your base mesh cell aspect ratio to unity (equal length in x y and z direction), the better results you will see in SHM. Try:
blocks
    hex (0 1 2 3 4 5 6 7) (880 480 1) simpleGrading (1 1 1)
and maybe change your z-thickness to 0.025 to match the aspect ratio of the x and y-directions. With your current settings of levels 6 7 you have cells that are on the size of 0.025/(2^6) = 3.9E-4 [m] to 0.025/(2^7) = 1.95E-4 [m].
s.m likes this.
Old   July 9, 2013, 11:47
s.m
saeideh mohamadi
blocks
thank you,is my cells size good or i should increase the level of refinementSurfaces?
Old   July 9, 2013, 11:50
Daniel P. Combest
...is my cells size good or i should increase the level of refinementSurfaces?
This ultimately depends on your y+ and turbulence model you are using so I can't comment on it. To snap to the surface, it should be fine.
Old   July 9, 2013, 12:07
s.m
saeideh mohamadi
i have both high-Re and low-Re number turbulent model, "k-wSST & lunderSharmaKE" would you please guide me?
is this cell size belong to all the cells around my airfoil? i ask this question, becuase for computing the y+ i only need to know the first cell size of my mesh.
thank you again for your advice
Old   July 9, 2013, 12:14
Daniel P. Combest
From my experience
lunderSharmaKE needs y+ <= 1
but it really can't be calculated until your simulation has been run to know how much further you need to refine your mesh. You can use the yPlusRAS utility to calculate the y+ value.
s.m likes this.
Old   July 9, 2013, 12:37
s.m
saeideh mohamadi
From my experience
yes you are right. for reducing my y+ to be appropriate for low-Re number turbulent models, i should increase the subdivision in blockMeshDict, is it right?
is it better to use level (6 6) for the refinementSurface, to have squre cells size?
Old   July 9, 2013, 13:02
Daniel P. Combest
the (6 6) would mean that if a featureEdge is encountered then the same refinement (a level 6) will be used. If you had done a (6 7) then a further refinement of 7 would be done around the "turn" of the edge.
s.m likes this.
Old   July 9, 2013, 13:20
s.m
saeideh mohamadi
Thank you i am running the case, with new blockMeshDict and also new snappyHexMeshDict. i'll put the resulted logFile after fininshing.
Old   July 10, 2013, 08:08
s.m
saeideh mohamadi
i didn't recive that message anymore, thank you very much for your kind help.
i put some picture of my mesh, would you please tell me is this mesh looks good?
and i also attach the snappyHexMesh and checkMesh logfile.
as you see in checkMesh, "Mesh non-orthogonality Max: 59.5431 average: 7.46241" is it fine?
thank you very much again
Old   July 10, 2013, 08:15
s.m
saeideh mohamadi
and these are, another picture of this snappyHexMesh, as you see ot just doesn't capture the main trailling edge corner angle true,if you have a comment to fix it, please tell me
thanks.
Old   July 10, 2013, 12:38
Daniel P. Combest
This is fine, anything above a 70 would be a concern.
also...if you are doing a 2D case, you will be better off doing a 2D mesh. have a look at
tutorials/incompressible/pimpleDyMFoam/wingMotion/wingMotion_snappyHexMesh
for some inspiration on how to generate a 2D mesh.
For resolving the edge, you could try drawing a refinement box around the edge and then make the cells there really small. Lastly, to make your mesh look better in screenshots (i.e. get rid of diagonal cuts in hex cells) you can check "use VTKPolyhedron" in Paraview object inspector when you first import results into Paraview.
Old   July 10, 2013, 13:17
s.m
saeideh mohamadi
yes, i looked at it some times ago, i didn't check "use VTKPolyhedron" anyTime, but i examine it now, it was really nice. thank you very much
i have another problem yet
as you see, the mesh around the airfoil is extremely tiny but, i get the pressure countour around it really bad.
i write my problem in the solving forum of openFoam.
Home > Forums > OpenFOAM Running, Solving & CFD > wrong contour of pressure at the airfoil leading edge
would you please take a look at it,thank you.
Old   July 10, 2013, 13:33
Daniel P. Combest
I will leave that thread to the experts. However, you may want to add some boundary layers cells to your mesh and/or increase the refinement near the surface. If you give as much info as possible on that thread and also search the forum....i bet you will get it solved. Good luck!
s.m likes this.
Old   July 10, 2013, 13:47
s.m
saeideh mohamadi
I will leave that thread to the experts. However, you may want to add some boundary layers cells to your mesh and/or increase the refinement near the surface. I'm not an expert at airfoils so if you give as much info as possible on that thread and also search the forum....i bet you will get it solved. Good luck!
ok, thank you
[snappyHexMesh] Disturbance in the mesh after the addition of layers Dorian1504 OpenFOAM Meshing & Mesh Conversion 0 June 13, 2017 02:27
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
