[mesh manipulation] changing initial condition for the velocity
Old   March 4, 2013, 10:21
Default changing initial condition for the velocity
atheel
jameel is on a distinguished road
Dear foamers
I am trying to simulate splashing a liquid bubble in side a cuboid by using interFoam. My case is 3D incompressible, laminar. I have changed the dambreak case to be like what I want and used setFields utility to create this liquid bubble inside my region. Now I want to give this liquid bubble initial condition for velocity and make it 2.89 m/s rather than 0, but i do not how to do it. Do i have to change just the U dictionary in the 0 folder, and If so, how?
please any one has an idea or suggestion because I am new in OF....
atheel,
jameel is offline   Reply With Quote
Old   July 22, 2013, 05:02
cutter is on a distinguished road
sorry for the late reply, hope it's still useful. As far as I understand you've already used the setFields utility to set the alpha field. You can use the same tool to set U vector field to the desired value for the bubble domain.
Cutter
cutter is offline   Reply With Quote
Old   July 22, 2013, 07:31
sandy
sandy13 is on a distinguished road
Originally Posted by cutter View Post
Cutter
Thanks cutter, I already solved it as you recommended, cheers..
jameel,
sandy13 is offline   Reply With Quote
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
