[Other] Create internal wall for a jet-pump
Old   August 13, 2013, 10:15
Default Create internal wall for a jet-pump
tarik
theshaq28 is on a distinguished road
Hi everybody, i'm trying to mesh a jet-pump componed of a venturi pipe and un little cynlinder which is in th venturi pipe. When I mesh it with Salome, OpenFoam consider jet's wall like a face zone, no like a patch.
How can I define internalwalls for an unv file converted to OpenFOAM.
Thank you
theshaq28 is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 04:15
Use Wall Friction velocity for calculation in internal Field juhuettn OpenFOAM Programming & Development 0 March 4, 2015 10:57
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 15:22
