[Other] Material properties in multi region foam and refining mesh for each region |
October 6, 2013, 21:20 |
Mominul MuKuT
Hello foamers!
I have modified the multi_region_heater tutorial and the final domain is as follows: The regions are as follows: Fluid/air: Top air Bottom air Solid: left solid as top electrode right solid as lower electrode heater as dielectric inner elec as inner covered electrode Problem#1: How can I select material properties of each solid region? For example the electrode material is copper and dielectric material is kapton. How can I fix these material? Problem#2: In paraFoam, when I activate "include zones" then all above mentioned regions have been appeared in left column under Mesh Parts. Innerelec region is created by me which was not included in original tutorial. As I create this new zone, so in system directory shall I make a folder name Innerelec manually as there are several folders for each default region created in original tutorial. Actually after modifying the original domain I have found some more folders like as follows: How can I identify those unwanted region as shown above domain2, domain3, domain4? In side of these three folders have two blank files name as fvScheme and fvsolution dict files only. Problem#3: How can I refine mesh size for each region? |
October 7, 2013, 01:56 |
#2 | ||
Nima Samkhaniani
Rep Power: 24 |
#problem 1
in constant folder, in each zone folder there is a file name called thermophysicalProperties , you can assign material properties there #problem 2 those folder names create by following command Quote:
#problem 3 it can be done with following command: Quote:
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
October 7, 2013, 02:08 |
Mominul MuKuT
Thanks bro for your point by point reply. I am trying now... will update soon
material constant, multi regions, openfoam, refine mesh, region meshing |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
