[mesh manipulation] "moveDynamicMesh -checkAMI" problem |
October 30, 2014, 08:04 |
chen long
Rep Power: 13 |
Hi Foamers
I try to use OF 2.3.0 the tutorial file propeller to simulate the flow around tidal turbine. When I try to type moveDynamicMesh-checkAMI It shows Code:
--> FOAM FATAL ERROR: request for volVectorField U from objectRegistry region0 failed available objects of type volVectorField are 0() From function objectRegistry::lookupObject<Type>(const word&) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #3 Foam::Q::execute() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libutilityFunctionObjects.so" #4 Foam::OutputFilterFunctionObject<Foam::Q>::execute(bool) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libutilityFunctionObjects.so" #5 Foam::functionObjectList::execute(bool) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::Time::run() const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #7 Foam::Time::loop() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #8 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/moveDynamicMesh" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/moveDynamicMesh" Aborted (core dumped) |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
