[snappyHexMesh] Debug option in snappy / Write volScalarField with cellLevel for postprocessing
Old   January 21, 2014, 08:33
Default Debug option in snappy / Write volScalarField with cellLevel for postprocessing
Julian Langowski
Ruli is on a distinguished road
Dear Foamers,
every now and then I try to set the debug option in snappy from 0 to 2, as it would be a nice and easy way to display cellLevels in paraview. Anyway, I am getting errors and snappy doesn work properly. I use OF 2.2.2.
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
1.) Is this a common problem?
2.) If not, is there a workaround this problem?
3.) Is there another way to obtain cellLevels for paraview postProcessing?
Thanks and best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   March 30, 2014, 08:57
Julian Langowski
although it is a little out of date, I am still interested in a solution of this problem. Any thoughts?
Best regards
Julian
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 13:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
