[Salome] Salome Mesh: How to create compound mesh group? |
May 11, 2015, 05:31 |
harshawardhank
Rep Power: 13 |
Hello friend
Can you tell me how to create group for compund Mesh in salome Thanks Harshawardhan |
June 20, 2015, 14:32 |
Anil Kunwar
Rep Power: 11 |
Hi Harshawardhan,
For the context here, please elaborate more about "Compound Mesh"? If it means Mesh in Multiple Bodies, then i generally do the following things for a 2D mesh. 1. Partition a geometry into two parts (or more if needed) Step: Code:
Geometry -->> Operations -->> Partition 2. Explode Partition 1 into (a) Faces and (b) Edges Step: Code:
Geometry -->> New Entity -->> Explode 3. After meshing and computing mesh, create Mesh Group. Step: Code:
Mesh -->> Create Group 4. Export Mesh in the required format. Step: Code:
Mesh -->> Export Note: Geometry and Mesh above mean the "Geometry" and "Mesh" modules of Salome Software. Yours Sincerely Anil Kunwar |
[Other] Error while tring to convert mesh generated in salome to openfoam | Arjun Jayakumar | OpenFOAM Meshing & Mesh Conversion | 0 | October 10, 2014 08:46 |
[Salome] Error while tring to convert mesh generated in salome to openfoam | Arjun Jayakumar | OpenFOAM Meshing & Mesh Conversion | 0 | October 10, 2014 08:23 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
