[Other] dynamicMeshDict setting for floating box
Old   January 19, 2016, 20:19
Default dynamicMeshDict setting for floating box
Baris (Heewa)
shipman is on a distinguished road
Dear Foam users,
I am trying to make floating box simulation similar as indicated in this video: http://www.youtube.com/watch?v=bb9lhV6HgMQ
To do this, I used the interDyMFoam/floatingBox tutorial case for a sample. Since, I use the dynamic mesh utility first time, I could not decide which option I should use in dynamicMeshDict. I want box to move with the wave therefore, floatingbox tutorial dynamicMesh option is not fit to this. After searching, I found following linearMotion option:
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
    patches      floatingObject;
    solidBodyMotionFunction     linearMotion;
    linearMotionCoeffs
         velocity (1 0 0);
Even the box is moving with this option, however the box looks fixed and not only box but also all domain is moving.
could someone tell me which dynamicMEsh option I should use to make similar simulation as indicated in the video.
Thank you.
shipman is offline   Reply With Quote
Old   January 27, 2016, 03:07
Baris (Heewa)
Noone has any experience about this topic before?
Old   August 4, 2016, 05:12
Default dynamicMesh doc
anonymous
iy-a is on a distinguished road
I think you refer to solidBodyMotionFvMesh option, which allows the whole mesh to be translated/rotated. dynamicMesh is well explained in the second link :
http://openfoam.org/release/2-3-0/mesh-motion/
http://fr.slideshare.net/fumiyanozaki96/openfoam
cheers,
iy-a.
iy-a is offline   Reply With Quote
How to create a box inside another box sy2516 FLUENT 0 December 1, 2017 16:42
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
I can't understand the moving function of "libfvMotionSolver.so" in dynamicMeshDict Jung hoo OpenFOAM Programming & Development 0 July 13, 2016 03:36
Natural Convection around two spheres in a box - chtMultiRegioSimpleFoam salvo-K61IC OpenFOAM 4 January 16, 2015 13:27
[DesignModeler] simply model, empty box conquer ANSYS Meshing & Geometry 0 March 28, 2014 18:26
