[snappyHexMesh] feature edges ignored for a pipe |
July 28, 2022, 09:47 |
Wolfram Schneider
Rep Power: 8 |
Hi all,
I am trying to mesh a cylinder with a propeller inside. sHM ignores the feature edges provided by the in- and outlet of the cylinder, while inner feature edges provided by the propeller are captured properly. Screenshot 2022-07-28 140823.jpg The error message by sHM is shown below: Code:
Refinement phase ---------------- Found point (0 0 0.05) in cell 43665 on processor 0 Reading external feature lines. Refinement level 2 for all cells crossed by feature "rrInlet.eMesh" (72 points, 72 edges). Read feature lines in = 0.06 s Feature refinement iteration 0 ------------------------------ Marked for refinement due to explicit features : 0 cells. Determined cells to refine in = 0 s Selected for feature refinement : 0 cells (out of 135000) Stopping refining since too few cells selected. Surface refinement iteration 0 |
July 29, 2022, 02:49 |
M
Rep Power: 12 |
What refinement levels are you setting for the surfaces and edges?
July 29, 2022, 02:59 |
Wolfram Schneider
Rep Power: 8 |
July 29, 2022, 03:25 |
Yann
Rep Power: 26 |
Hi Wolfram,
Could you post your snappyHexMeshDict so we can have a look? Yann |
July 29, 2022, 03:33 |
#5 | |
Wolfram Schneider
Rep Power: 8 |
snappyHexMeshDict.txt |
July 29, 2022, 04:15 |
Yann
Rep Power: 26 |
Thanks!
Have you tried switching from implicitFeatureSnap to explicitFeatureSnap? AFAIK you have to be in explicit mode in order to use the parameters defined in the features subdictionary for snapping. Code:
// Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; // Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; How do you visualize the eMesh files in paraView ? The snapping issue on the cylinder also might be related to the use of separate STL files rather than one single STL for the whole cylinder. This is probably another thing worth trying. Yann |
July 29, 2022, 04:36 |
M
Rep Power: 12 |
Another thought: resolveFeatureAngle seems offly high. Try 30.
July 29, 2022, 04:42 |
Wolfram Schneider
Rep Power: 8 |
July 29, 2022, 06:17 |
#9 |
Nico
Rep Power: 6 |
Hey,
you couldtry to use a single eMesh file. I have noticed i a log file that always only one was used and this one wasn't even the desired region. Apaprt from that make sure that the stl used to extract the eMesh is also closed that way you should be able to utilize the eMesh. And try to use the explicit snapping! Hope i could help. |
July 30, 2022, 13:21 |
#10 | |
Wolfram Schneider
Rep Power: 8 |
I tried to use the single eMesh. It is the circle in the screenshot. Unfortunately the error is persistent. |
August 1, 2022, 01:19 |
#11 |
M
Rep Power: 12 |
Another shot in the dark: strange things can happen during the run, if the prescribed locationInMesh hits a face or node. Your choice seems likely to hit one of these on the background mesh or refined mesh during the castellatedMesh process.
To avoid this, use slightly off float numbers, in your case (0.00013 -0.00031 0.050012) for example. Maybe this fixes things. |
August 1, 2022, 02:28 |
#12 | |
Wolfram Schneider
Rep Power: 8 |
the eMesh file is shown in my screenshot. It looks reasonable. I used 3 separate stl files to define the entire cylinder in order to obtain three different patches (inlet, wall, outlet) |
August 1, 2022, 06:13 |
#13 | |
Yann
Rep Power: 26 |
You can concatenate the 3 stl into one in order to have 1 single STl containing the different patches you need for your case. Have a look at this post, it looks a bit similar to your issue: snappyHexMesh - 90° edges problem Problem has been solved by using one single closed STL rather than several separate files. Yann |
August 2, 2022, 03:58 |
#14 |
Niels Nielsen
Rep Power: 27 |
Hi
I have no issues with meshing a pipe both with Implicit and Explicit feature edges. Implicit is even a tad better. I'm using OpenFOAM 2206 If you want to use multiple STL files remember that in the surfaceFeatureExtractDict file to enable the line in bold. Otherwise it will not generate edges at the open end of the pipe. I like to use separate STL files to better control what edges get refined and which don't. Forgot to ask, which version of OF are you using? If its 4.1 which is listed in the uploaded dict then snappy was not good at snapping at the time. EDIT: Just tried with 4.1 and it worked just fine. Code:
wallOuter.stl { extractionMethod extractFromSurface; extractFromSurfaceCoeffs { includedAngle 150; } subsetFeatures { // Keep nonManifold edges (edges with >2 connected faces) nonManifoldEdges no; // Keep open edges (edges with 1 connected face) openEdges yes; } writeObj yes; } https://holzmann-cfd.com/community/t...meshing-a-pipe
Linnemann PS. I do not do personal support, so please post in the forums. Last edited by linnemann; August 2, 2022 at 05:27. |
August 3, 2022, 11:16 |
#15 | |
Wolfram Schneider
Rep Power: 8 |
Many thanks for your input. I am playing now for hours, among other things with the files from Tobias as mentioned I tried now an combined stl-file which I merged with the "cat" command. Still the edges are not captured ... Were you able to call the surfaceFeatureExtractDict within foam-extend4.1? Typing "surfaceFeatureExtract" in fe41 does not work, thus I created the .eMesh-files with OF2012 - maybe this is the problem??? Edit: In OF2012 the edges are captured o.O |
August 4, 2022, 07:34 |
#16 |
Niels Nielsen
Rep Power: 27 |
Hi
Over the years I have really just decided to stick with the OpenFOAM.com version. At a certain time .ORG, .COM and EXTEND was pretty much compatible. Nowadays they have diverged enough that you need to tinker with many of the standard files to switch between them. RANT BEGIN See for example moving meshes, CGI (extend), AMI (com) and now NCC (org). Why could they not just rework AMI so we could continue using the same setup? Guess that's what happens when egos meet opensource collaboration. RANT END I only ever switch from COM version if there is a feature I really need from the other.
Linnemann PS. I do not do personal support, so please post in the forums. |
August 4, 2022, 08:05 |
#17 |
Yann
Rep Power: 26 |
This is also true here on the forum. It gets harder to help people as the answer might vary according to the version used in the initial post, and I guess it must also be confusing for new users searching the forum and finding answers they cannot apply on the version they use.
August 5, 2022, 06:11 |
#18 | |
Wolfram Schneider
Rep Power: 8 |
Well, I was also comfortable with the .com version. But for steady turbomachinery applications I am dependent on "mixingPlanes". As far as I know, foam-extend is the only version offering this functionality? Were you able to employ the "surfaceFeatureExtractDict" within foam-extend? Right now, this seems to be the biggest obstacle for me of using sHM in foam-extend. |
August 5, 2022, 07:09 |
#19 |
M
Rep Power: 12 |
Too lazy to really look into it (I use it with -ESI versions and it works nicely), but I think the command is named differently in -dev version "surfaceFeatures"? And it seems there are more differences for the -extend version?
.eMesh with foam-extend. surfaceFeatureExtract does not work. |
[snappyHexMesh] SHM: sharp edge resolving problem with explicit feature edges | piotr.mecht | OpenFOAM Meshing & Mesh Conversion | 21 | May 9, 2020 14:56 |
[snappyHexMesh] Extract feature edges in paraview | strakakl | OpenFOAM Meshing & Mesh Conversion | 2 | August 29, 2019 13:57 |
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam | wuyangzhen | OpenFOAM | 10 | December 12, 2017 00:19 |
[surface handling] SurfaceFeatureExtract Foam::error::printStack | donQi | OpenFOAM Meshing & Mesh Conversion | 1 | August 15, 2013 00:43 |
Double Walled Pipe Boundary | dahvqaz | FLUENT | 2 | December 5, 2012 10:14 |
