[Commercial meshers] problem meshing two interacting volumes
Old   December 14, 2009, 15:59
Question problem meshing two interacting volumes
banerji
banerji is on a distinguished road
my case is a pipe passing thourgh a box. I want to model the propagation of radiaton inside the box and model flow in the pipe but i need also propagation of radiation in the pipe. I made a hole into the box that means there is face in contact with the outwall of the pipe. I have a problem merging those two faces hoping to get radiatoion disptribution of radiation into the pipe but have a boundary so that when I model water only inside the pipe. Does any body have an idea? When I tried Fluent only modeled each volume separately I am not getting the radiation to pass though pipe wall even though it is transparent.
banerji is offline   Reply With Quote
gambit and fluent
3D Cyclone meshing problem Wayne12195 Mesh Generation & Pre-Processing 0 September 25, 2018 01:45
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem dalecooper ANSYS Meshing & Geometry 0 July 19, 2013 07:04
[ICEM] Meshing problem in Formula one Far ANSYS Meshing & Geometry 113 April 23, 2013 12:36
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 11:27
