[blockMesh] BlockMesh: Strange interface between blocks
Old   May 25, 2010, 20:42
Default BlockMesh: Strange interface between blocks
Daniel
dancfd is on a distinguished road
Hello all,
I am a beginner at OF1.6 and I am struggling to understand the problem with a C-grid I created for an airfoil. As shown in the pictures of the mesh, the interface between blocks 0-1 and 2-3 feature a "crossover" of the mesh from one surface of the 2-D mesh to the other. I do not get any errors when running blockMesh or paraView, yet this inconsistency persists. I would appreciate any help you could offer.
Regards,
Dan
dancfd is offline   Reply With Quote
Old   May 26, 2010, 19:23
Default Found problem
Daniel
I apologize for bothering the board with a rookie error. For those who are curious, I had not defined the blocks with a right-hand coordinate system as required in User Guide page U-134. It was convenient to use left-handed coordinate systems in some blocks so that I could use the same expansion ratio in the y-direction for all blocks. Now it is a matter of using the inverse expansion ratio for the blocks I had arranged in a left-handed coordinate system.
Dan
Old   June 8, 2010, 10:01
kjetil is on a distinguished road
Right. BlockMesh is strict on how you define your blocks.
Are you attempting to reproduce the Fluent tutorial for an airfoil? Seems like you have quite a coarse mesh, and to be "missing" a mesh-section behind the airfoil. But you might parhaps have thought of this already
kjetil is offline   Reply With Quote
Old   June 8, 2010, 16:54
Daniel
In fact I have never used Fluent, but it is good to know that there is a similar tutorial out there. I agree, the mesh is very coarse, and this was done intentionally to more effectively show the "disturbance" in the mesh. I did try several refined meshes, but the problem did not disappear until I fixed the left-handed coordinate system.
I appreciate your reply.
Regards,
Dan
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
