[Other] Dynamic Mesh Changing Shape
Old   June 6, 2010, 19:43
Default Dynamic Mesh Changing Shape
Daniel
dancfd is on a distinguished road
Hello all,
I am struggling to produce a dynamic mesh whereby an airfoil surrounded by a 2D C-grid changes shape in an oscillatory manner as a function of time. Specifically, I would like to make the airfoil oscillate, and also make a flap oscillate on the airfoil at a different periodicity.
From a survey of the boards, I have found code for older versions of OF that use oscillatingFixedValue to make the airfoil oscillate; however this code does not work in OF1.6 nor does it allow the flap to oscillate relative to the airfoil.
Is there a way to make this happen? I would appreciate any ideas.
Thank you,
Dan
dancfd is offline   Reply With Quote
Old   June 13, 2010, 22:09
Default Closer to a solution
Daniel
I believe I can accomplish what I need by setting the airfoil boundary to type timeVaryingMappedFixedValue in the pointMotionUx file (to be used by a dynamicMeshDict with solver velocityComponentLaplacian). This presents a problem, though: timeVaryingMappedFixedValue requires a "points" file in a /constant/boundaryData/<boundaryName>/ directory. Since the mesh will be moving, I must specify a "points" file for each time step, and I do not think timeVaryingMappedFixedValue can handle that.
Does anyone have an idea of how I could overcome this last hurdle? I think that if I can make timeVaryingMappedFixedValue read a "points" file for each time step, I might have this problem solved.
Thank you,
Dan
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
