[Commercial meshers] ccm26ToFoam interfaces
Old   November 24, 2010, 05:35
Default ccm26ToFoam interfaces
Martin80 is on a distinguished road
I have used ccm26ToFoam and got several cell zones written in polyMesh/sets and some interfaces between the cellzones. Is there an application which merges the cell zones, deletes the interfaces (lets call it interf1, interf2) and renumbers the lists in
polyMesh/boundary
polyMesh/faces
polyMesh/owner
appropriately.
Maybe someone has an hint,
Martin.
Martin80 is offline   Reply With Quote
Old   November 24, 2010, 10:51
1.) I have found one possibility buy using mergeMeshes and stitchMesh. But I had to export the volume meshes (for example 2) separately and create 2 meshes in OpenFoam.
2.)If I am having more then 2 volumes this strategy seems to be elaborate, therefore I want to export the ccm+ volume meshes to one .ccm file and create one OpenFoam mesh with several cellZones.
Is there way to merge these cellZones to one cellZone without interfaces.
B.r.,
Martin.
Old   December 1, 2010, 07:47
Just in case someone else runs into same troubles by connecting more domains: mergeMeshes, stichMesh for connecting more than 2 volumes did only work with 1.7 (and did not with 1.6) on my computer.
I'm using ccm26ToFoam and now (the other way around) I'm searching for an openFoam tool to export the geometry into a ccm+ readable format.
Maybe someone has a hint,
m.
Mesh Interfaces not showing - Cooling Plate tom96 FLUENT 3 July 24, 2018 12:49
Discontinuity across interfaces Nurzhan CFX 2 March 11, 2015 01:59
What type is defined as the interfaces between stator and stator on OF-2.1.1? renyun0511 OpenFOAM Running, Solving & CFD 3 May 18, 2013 08:11
Subdomain or Interfaces (CHT) sandeep_tu CFX 8 July 14, 2009 11:06
grid interfaces kiko FLUENT 0 February 13, 2007 10:28
