[snappyHexMesh] incompleted faceZones ? normal?
Old   November 30, 2010, 10:02
Default incompleted faceZones ? normal?
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi together,
meshing a length of a pipe with snappyHexMesh.
So everything is working but i am not sure if the faceZones could have those gaps or if this is normal? The simulation is running and the solver also runs but i don't know if those gaps manipulate the result.
Here the mesh after meshing:
FaceZones - Incomplet / with gaps:
Last Picture - all three faceZones activated - and the gaps from one faceZone is filled with the other one. But if i generate the same mesh with blockMesh i've got no gaps.
How can i reduce the gaps ?
And are they manipulating my result while solving?
Best greetings
Tobi
Hope someone can help me.
Tobi is offline   Reply With Quote
Old   November 30, 2010, 13:42
Tobi's Avatar
Tobias Holzmann
Hey together, its me again.
I heard that the faceZones don't matter if you use cht... solver. So i think there 's nothing else to say.
Tobi
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 07:49
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
