[snappyHexMesh] SurfaceLayers on a endless circular cylinder
Old   December 11, 2010, 07:41
Default SurfaceLayers on a endless circular cylinder
Wolfgang Strauss
WolfgangS. is on a distinguished road
hi foamers!
I have a problem with my surfacelayers. i use to simulate a flow over a endless circular cylinder. How you can see on the picture my layers do not go till the frontAndBack-patches. Is it normal that the layers where built from the outside-patches? I am new in OpenFOAM please help me!
// Settings for the layer addition.
addLayersControls
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
geodata1_patch0
nSurfaceLayers 7;
// Expansion factor for layer mesh
expansionRatio 1.0;
//- Wanted thickness of final added cell layer. If multiple layers
// is the
// thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
finalLayerThickness 0.9;
//- Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
//- If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
nGrow 1;
best regards
Wolfgang
WolfgangS. is offline   Reply With Quote
Old   January 13, 2011, 06:10
Silvan Brändli
s_braendli is on a distinguished road
Hi Wolfgang
I noticed the same thing, but as I'm not very experienced in meshing either, I don't know if this is normal, or just our mistake...
Best regards
Silvan
s_braendli is offline   Reply With Quote
Old   January 25, 2011, 11:02
D.S. is on a distinguished road
Hi Wolfgang,
try this : set your front+back from patches to empty. then run snappy. if the layers are ok and you want to run your case you have to manually overwrite the front+back in your boundary file ( from empty to wall/etc. ).
hope it works
D.S. is offline   Reply With Quote
Flow over a circular cylinder, Re=8000, Problem with cd david caseiro FLUENT 4 October 10, 2017 10:18
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 10:42
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM Running, Solving & CFD 0 November 2, 2013 04:32
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
