[Other] Meshing?
Old   March 7, 2016, 06:52
Default Meshing?
Alpha Beta
xoitx is on a distinguished road
Is meshed area, the area within which the fluid will be flowing?
That is my understanding of mesh.. correct me if I'm wrong.
If so how do i include obstacles like a baffle plate.
I'm attempting to study sloshing in tanks (cylindrical)... any ideas?
I want to use gmsh or salome to do that so it's easier.. so how do I design the baffle plate?
Will it be a solid within a solid (using Boolean operation to delete mesh where baffle plate is supposed to be)? Cause I intend to get the stress values on the plates as well.
xoitx is offline   Reply With Quote
Old   March 7, 2016, 08:16
Alex
Kina is on a distinguished road
that's correct!
those are the areas left out in the meshing, as you wrote with a boolean operation. only the fluid is meshed.
For this, you would have to implement an FSI (1 way should work). That way, you can project the pressure field of the CFD simulation onto a mechanical model of the baffle and let FEM calculate the stresses. Is that what you are trying to achieve?
Cheers
Alex
Kina is offline   Reply With Quote
Old   March 7, 2016, 11:10
Alpha Beta
What I'm trying to achieve is a simulation of what sloshing looks like without a baffle plate and also with a baffle plate but in various orientations/designs so as to get optimum effect.
My understanding so far is that I have to do the Boolean thing and get the effect without the actual model so that fluid is sloshing mid-air without any container :O .. then somehow add container later via blender or something... Is this right?
And after I get meshed entity.. how do I slosh it about? :P (I have to fill container to a certain percentage.. is there a variable for this? or do I have to keep meshing about?)
Any kind of help is appreciated
Old   March 7, 2016, 11:14
Alpha Beta
[QUOTE=Kina;588464
Cheers
Alex[/QUOTE]
Pretty much .. but I'll do that later if I have time .. I could just run a simple stress analysis on the plate for now.
Old   March 8, 2016, 02:06
Alex
I get a little confused with your terminology of 'stress". Do you mean forces or fluid pressure exerted on the baffle plate? In CFD, we don't explicitly design the solids around the fluid. In CFD, there is only fluid or not fluid. You would do "the Boolean thing" and define the face between the baffle plate and the fluid as "baffle wall" and then monitor the pressure and forces of this wall during the calculation.
I strongly recommend reading the damBreak tutorial. This will give you a first idea of what you might want to realize in terms of setup.
Old   March 11, 2016, 09:48
Default Help!!
Alpha Beta
Hi Kina
I successfully ran the SloshingTank3d tutorial in the interDymFoam folder
That is basically what I'm going for..
I tried to make a cylinder mesh with a boolean cut inside using salome.
I meshed it and then created a surface group for the whole thing as 'walls' , exported it as unv and used ideasUnvToFoam and setfields and finally interDymfoam.
The whole thing worked.
But I cant see the moving water inside.. Its just the empty cylinder with a boolean cut inside swaying. Can't I use 'boxtocell' inside a cylinder? How do I half fill the cylinder? I'm assuming it's something other than 'boxTocell' although I don't see how this is a problem.. It should just fall down and splash all over.. right?
And is the mesh right?
I meshed it in Salome and then created "surface" group and grouped it as 'walls'
In paraview it seemed wrong as only the surfaces were meshed.. there was no mesh inside the volume.
I tried meshing and grouping as "volume" but the setfields command returns an error.. I'm guessing this method is totally wrong
I don't know if its the mesh that's wrong or the setFieldsdict
Please do Help.
Thanks
Old   March 17, 2016, 13:48
Alpha Beta
Hot a better way.. toposetdict contains some useful info on setting up the water phase (alpha.water file).
I'm using
regions
targetVolumeToCell // Fills volume below given plane
volume 7.86905;
normal (0 1 0); // usually in direction of gravity
fieldValues
volScalarFieldValue alpha.water 1
to half fill any structure.
In case anyone needed to know :P
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 14:27
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
