[snappyHexMesh] SnappyHexMesh: parameter & refinement choice |
August 19, 2011, 02:03 |
Rep Power: 15 |
Hi @ all,
for a few weeks I'm working with OpenFOAM 2.0.0. So I don't have much experience working with it. Now I'd like to mesh a complex geometry with snappyHexMesh. Snappy is working fine and the created mesh looks good, but when I check the mesh with checkMesh some errors occur, like: ***Error in face pyramids: 45 faces are incorrectly oriented. <<Writing 45 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 6.578289, 3 highly skew faces detected which may impair the quality of the results <<Writing 3 skew faces to set skewFaces It gets even worse when I do further refinements. I guess there are several ways to avoid these errors. So I tried to change some parameters in snappyHexMeshDict but without success. The mesh quality didnt raise. So, can anybody give me some advice, what's a good choice for parameters in snappyHexMeshDict? Another point I'd like to know is the choice of refinement. Is it better to generate a coarse mesh with blockMesh and do the refinement with snappy or to make a fine mesh with blockMesh and less refinement with snappy? Thanks a lot for your help. Marango |
August 29, 2011, 07:15 |
Rep Power: 16 |
Hi marango,
I also experienced these wrong oriented faces with OF2.0.0 Before I had never such an error. It could be this error comes from the new snap feature although I'm not sure.
"When I meet God, I am going to ask him two questions: Why relativity? And why turbulence? I really believe he will have an answer for the first." Werner Heisenberg
August 30, 2011, 04:08 |
Rep Power: 15 |
Thanks val46 for your reply. That's a good hint and I try find out whether the error is created by the new feature.
I also tried another way. I decreased the mesh quality and chose a very low value for minTetQuality. Now the error didn't appear but the the generated mesh was not usable. I guess the problem could also be a matter of finding the right parameters for snappy... |
[snappyHexMesh] SnappyHexMesh Problem | 96faizizzuddin | OpenFOAM Meshing & Mesh Conversion | 10 | October 10, 2022 06:45 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
[snappyHexMesh] snappyHexMesh not refining surfaces | Hydro1004 | OpenFOAM Meshing & Mesh Conversion | 3 | August 29, 2012 11:56 |
