[snappyHexMesh] Dirty STL with small gaps
Like Tree4Likes
  • 4 Post By novak1203
Old   November 30, 2011, 07:58
Default Dirty STL with small gaps
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello foam-ers,
I would like to study the flow around a volume which has an exterior shape describe by an STL surface. The STL is rather dirty and has gaps (in other words it leaks). However, I want to use snappyHexMesh to generate a mesh on the outside of this surface.
What is the usual way of closing the gaps? Otherwise I end up with mesh in both sides of the surface.
I've seen an undocumented option "gap 0.005" (documents snappyHexMesh) but I cannot understand how to use it.
Thanks,
Dragos
dmoroian is offline   Reply With Quote
Old   November 30, 2011, 09:42
Default Re:
nbak skmt
novak1203 is on a distinguished road
Hello Dragos,
I don't know if you've already tested the following or not;
I usually use adMesh to fix incomplete STL file automatically.
If you work on Linux machine, (assuming Ubuntu or Debian) the software is wuite easy to get installed, e.g.
>sudo apt-get install admesh
Once you install it in your machine,
>admesh --help
will provide you detail instruction to use.
Hope it works.
Best,
Novak
Thom, calim_cfd, s.m and 1 others like this.
novak1203 is offline   Reply With Quote
Old   November 30, 2011, 12:04
dmoroian's Avatar
Dragos
Thanks Novak, I will definitely give it a try.
Dragos
Old   December 1, 2011, 02:11
Default Not yet successful
dmoroian's Avatar
Dragos
Well I tried it, but it changes structure of the surface. My original stl surface is composed out of many different surfaces, whereas the final output has only one (all the initial surfaces get merged into one).
Is there any way to keep the original surfaces (I think they are called parts in admesh)?
Dragos
Old   December 1, 2011, 03:06
nbak skmt
Dragos,
Well, so far I've just worked only on simple geometry (like bare ship hull without any appendages) and am afraid I have no idea to fix STL for complex geometries... Thanks.
Novak
Old   August 13, 2013, 18:15
s.m
saeideh mohamadi
s.m is on a distinguished road
Originally Posted by novak1203 View Post
Hello Dragos,
>admesh --help
Hope it works.
Best,
Novak
by executing the first step " sudo apt-get install admesh"
i give this error,
"sudo: apt-get: command not found"
can you guide me more obvious that what is the steps for installing admesh?
thank you very much.
s.m is offline   Reply With Quote
Old   August 14, 2013, 05:08
anonymous
aCFDuser is on a distinguished road
Hi Dragos,
You can manually edit your .stl file with remesh (http://remesh.sourceforge.net/). It works well under Windows and Linux (32bits, I think). It is very easy to use and the resulting .stl are usable by SHM. Another option is to use MeshLab (http://meshlab.sourceforge.net/), but I've had many problems with hole filling tool.
aCFDuser is offline   Reply With Quote
Old   August 18, 2013, 03:05
dmoroian's Avatar
Dragos
Well thanks,
I will definitely give it a try as soon as I'm in front of my desktop.
[snappyHexMesh] What CAD software do you use to define STL surfaces? Awak OpenFOAM Meshing & Mesh Conversion 11 November 12, 2020 11:00
[snappyHexMesh] Problems with stl from dem and background mesh VLima OpenFOAM Meshing & Mesh Conversion 1 May 4, 2020 12:04
[DesignModeler] Design Modeler to Stl format natantyt ANSYS Meshing & Geometry 0 December 9, 2013 15:55
[ANSYS Meshing] problem volume mesh with STL hadrien51 ANSYS Meshing & Geometry 0 June 5, 2013 10:34
[snappyHexMesh] orthogonality problem with raw STL file tellico OpenFOAM Meshing & Mesh Conversion 1 April 16, 2013 03:18
