[snappyHexMesh] Problem with layer generation
Old   January 4, 2012, 17:14
Default Problem with layer generation
Stefan
bobburnquist is on a distinguished road
Hi Foamers,
i want to generate layers in a small gap (1mm).
Here are my settings, with those i can see some layers:
blockMesh
hex (0 1 2 3 4 5 6 7) (30 30 20) simpleGrading (1 1 1)
// In z direction, i have to define 20 cells. With more or less cells, i can not see any layers.
snappyDict:
rau1mmzu
// Surface-wise min and max refinement level
level (2 2);
//levels 2 3, 3 4... are not possible.
refinementBox
mode inside;
levels ((1E15 1));
//level 2, 3... is not possible.
As u can see in the picture, the mesh is not fine enough. The surface of the rough stl is also not satisfactory.
I changed the layer thickness to false and defined the thickness (min and average) manually to the smallest size (without improvement)
Mabye someone is experienced in meshing a micrometer region, or have an idea.
Tomorrow, i will post my complete snappyDict.
Thanks
bobburnquist is offline   Reply With Quote
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh crizpi21 OpenFOAM Meshing & Mesh Conversion 5 October 16, 2021 10:56
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 07:48
[snappyHexMesh] Problem with snappyHexMesh samiam1000 OpenFOAM Meshing & Mesh Conversion 2 December 13, 2012 08:41
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
