Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraview cannot read data from time directories
Old   June 7, 2013, 23:20
Default paraview cannot read data from time directories
Yao Lu
shuoxue is on a distinguished road
A case has been solved exactly, and post-processing is dealed with paraview.
Select internalMesh in Mesh Parts →select all Volume Fields →apply →read data successfully.
Select all Mesh Parts →select all Volume Fields →apply →read data abortively.
What's wrong with paraview and Mesh Parts?
Thanks in advance.
shuoxue is offline   Reply With Quote
Old   June 9, 2013, 15:33
Retired Super Moderator
Bruno Santos
Greetings shuoxue,
This is not the first time someone asks about this. And the great thing is that the other person also had shown the images of when it works and when it doesn't. - It was this one: http://www.cfd-online.com/Forums/ope...tml#post400799 - post #8
And the trick is simple: compare the two images and you'll see that in the first one you have near to middle top of the image, on the second row of controls, the text "Surface"; while on the second image, you have "Outline".
This happens because ParaView tries to avoid very large meshes to be represented when it starts, which can lead to seriously slow start-ups, specially when people might not want to see all of the data right away.
Best regards,
Bruno
Old   June 9, 2013, 23:15
Yao Lu
I have tried according to your description, and it works.
Best regards.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 00:58
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
