[OpenFOAM] Having access to Time: field directly. |
August 25, 2013, 02:29 |
Ehsan
Rep Power: 26 |
How can have access to the time field in paraView 3.12.0 directly not through snapshot numbers?
I want to reach exactly to .000933s before the last snapshot and I have to reach there by trial and error! how can make this field accessible not to be grey?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
August 25, 2013, 05:59 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
That can be made accessible from the "Animation View" controls, which are shown by selecting it in the menu "View". Then change the "Mode" to "Real Time". The problem with this is that it will not give you a discrete position, become it provides a continuous time capability. In addition, the option "Duration" is the number of real wall clock seconds it takes to animate your simulation. The other possibility is to set the "Mode" to "Sequence", but you must already know how many time snapshots there are, so that you can set the option "No. Frames" to the same value. Best regards, Bruno
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
