Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview start problems
Old   September 14, 2013, 12:48
Default Paraview start problems
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I compiled Paraview-3.14.1 by myself successfully.
When I start paraview with mpirun or just paraview I got a segmentation faults.
shor-ty@cfd:~/OpenFOAM/ParaView-3.14.1$ mpirun -np 4 /usr/local/bin/pvserver
Warning: In /home/shor-ty/OpenFOAM/ParaView-3.14.1-Source/ParaViewCore/ClientServerCore/vtkPVServerInformation.cxx, line 127
vtkPVServerInformation (0x8098560): ProcessModule is not available.
Waiting for client...
[cfd:29845] *** Process received signal ***
[cfd:29845] Signal: Segmentation fault (11)
[cfd:29845] Signal code: Address not mapped (1)
[cfd:29845] Failing at address: (nil)
vtkPVServerInformation (0x81cc560): ProcessModule is not available.
[cfd:29846] *** Process received signal ***
[cfd:29846] Signal: Segmentation fault (11)
[cfd:29846] Signal code: Address not mapped (1)
[cfd:29846] Failing at address: 0x40
vtkPVServerInformation (0x72ce560): ProcessModule is not available.
[cfd:29848] *** Process received signal ***
[cfd:29848] Signal: Segmentation fault (11)
[cfd:29848] Signal code: Address not mapped (1)
[cfd:29848] Failing at address: 0x40
vtkPVServerInformation (0x8bc8560): ProcessModule is not available.
[cfd:29847] *** Process received signal ***
[cfd:29847] Signal: Segmentation fault (11)
[cfd:29847] Signal code: Address not mapped (1)
[cfd:29847] Failing at address: 0x40
[cfd:29846] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xfcb0) [0x7f2290a77cb0]
[cfd:29846] [ 1] /usr/local/bin/pvserver(_ZN16vtkProcessModule15RegisterSessionEP10vtkSession+0x34) [0x1bebe08]
[cfd:29846] [ 2] /usr/local/bin/pvserver() [0x15dba82]
[cfd:29846] [ 3] /usr/local/bin/pvserver(main+0x25) [0x15dbb7a]
[cfd:29846] [ 4] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f228ffa976d]
[cfd:29846] [ 5] /usr/local/bin/pvserver() [0x15db7d9]
[cfd:29846] *** End of error message ***
[cfd:29847] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xfcb0) [0x7fc24191fcb0]
[cfd:29847] [ 1] /usr/local/bin/pvserver(_ZN16vtkProcessModule15RegisterSessionEP10vtkSession+0x34) [0x1bebe08]
[cfd:29847] [ 2] /usr/local/bin/pvserver() [0x15dba82]
[cfd:29847] [ 3] /usr/local/bin/pvserver(main+0x25) [0x15dbb7a]
[cfd:29847] [ 4] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fc240e5176d]
[cfd:29847] [ 5] /usr/local/bin/pvserver() [0x15db7d9]
[cfd:29847] *** End of error message ***
[cfd:29845] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xfcb0) [0x7f7778137cb0]
[cfd:29845] [ 1] /usr/local/bin/pvserver(_ZN18vtkPVSessionServer7ConnectEv+0x59) [0x1a8515f]
[cfd:29845] [ 2] /usr/local/bin/pvserver() [0x15dba63]
[cfd:29845] [ 3] /usr/local/bin/pvserver(main+0x25) [0x15dbb7a]
[cfd:29845] [ 4] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f777766976d]
[cfd:29845] [ 5] /usr/local/bin/pvserver() [0x15db7d9]
[cfd:29845] *** End of error message ***
[cfd:29848] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xfcb0) [0x7fc96730fcb0]
[cfd:29848] [ 1] /usr/local/bin/pvserver(_ZN16vtkProcessModule15RegisterSessionEP10vtkSession+0x34) [0x1bebe08]
[cfd:29848] [ 2] /usr/local/bin/pvserver() [0x15dba82]
[cfd:29848] [ 3] /usr/local/bin/pvserver(main+0x25) [0x15dbb7a]
[cfd:29848] [ 4] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fc96684176d]
[cfd:29848] [ 5] /usr/local/bin/pvserver() [0x15db7d9]
[cfd:29848] *** End of error message ***
mpirun noticed that process rank 1 with PID 29846 on node cfd exited on signal 11 (Segmentation fault).
Can someone give me an advice? Well the file:
is avaiable.
Thanks in advance
Tobi is offline   Reply With Quote
Old   September 14, 2013, 12:57
Tobi's Avatar
Tobias Holzmann
Hi all,
I know how to solve the problem but not where to switch the lines.
While loading the terminal, I am loading the thirdparty paraview files.
If I comment the OF line in the bashrc then I can start my compiled paraview but the pvserver needs the mpi libs
So I have to deset the paraview variables in the thirdpartys.
Can someone give me an advice.
Old   September 14, 2013, 13:11
Retired Super Moderator
Bruno Santos
Hi Tobi,
If I understand you correctly, you need to comment out the following line from OpenFOAM's "etc/bashrc" file: https://github.com/OpenFOAM/OpenFOAM...tc/bashrc#L214
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/paraview.sh`
Best regards,
Bruno
[OpenFOAM.com] Problems compiling ParaView 5.4 suantaraDarma OpenFOAM Installation 3 August 22, 2018 09:19
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 08:09
ParaView does not start: ResizeEvent MatP OpenFOAM Installation 9 May 14, 2012 17:00
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Problems with paraView alejo OpenFOAM Pre-Processing 0 February 17, 2006 07:24
