Home > Forums > Visualization & Post-Processing Software > ParaView
[General] how assign dataset in python calculator?
Like Tree6Likes
Old   September 6, 2013, 16:34
Default how assign dataset in python calculator?
immortality's Avatar
Ehsan
immortality is on a distinguished road
for making a field for cells like aspect(dataset) in python calculator, whats dataset and how to set it?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   September 7, 2013, 11:47
Retired Super Moderator
Bruno Santos
Hi Ehsan,
It took me a while to figure this one out. I ended up figuring it out after I followed this tutorial: http://www.paraview.org/Wiki/ParaVie...tiple_Datasets
In conclusion, the "dataset" is "inputs[0]".
Best regards,
Bruno
sourav90 likes this.
Old   September 7, 2013, 11:58
Ehsan
Hi Bruno,
thanks for your consideration,
but the image doesn't show aspect ratios or area of cells.
Old   September 7, 2013, 12:06
Bruno Santos
It only works on surfaces, as shown in the attached picture.
And it barely works on tetrahedral cells, because it can calculate on some cells, but not on others.
File Type: jpg Screenshot from 2013-09-07 17:04:37.jpg (39.5 KB, 25 views)
Old   September 7, 2013, 15:30
Ehsan
thanks,then at first a plane have to be be separated by slice Filter? the cells are hexahedral.
Old   September 8, 2013, 09:51
Bruno Santos
Quick answer: Try the filters that extract faces and surfaces. I can't remember right now which ones they are.
All I know is that the slice filter will likely create triangles that don't exist in the original mesh.
Old   September 8, 2013, 11:08
Ehsan
Hi Bruno,
in the attachment the image is somewhat dark,how to resolve the shading?
Old   September 8, 2013, 15:27
Bruno Santos
You have to play with the light controls, which are accessible from the menu: Edit -> View Settings. The controls are shown in the attached image.
Try changing the values and hit the "Apply" button to see the result, without closing the dialogue box.
File Type: png Screenshot from 2013-09-08 20:25:11.png (39.8 KB, 19 views)
immortality likes this.
Old   September 8, 2013, 17:41
Ehsan
dear Bruno it seems its related to Slice selection that is dark still,I changed light parameters but it didn't become brighter.how can exit it from selection mode?
Old   September 9, 2013, 13:58
Bruno Santos
Hi Ehsan,
Without an example case and step-by-step instructions, I'm unable to reproduce the same problem.
Do you mean that it's the selection plane that the Slice widget provides, that is making it darker? There's an option on the "Display" tab on the lower left widget, that allows to not show the slice selection place.
Best regards,
Bruno
Old   September 9, 2013, 14:42
Ehsan
yes,
do you mention "selectable"? I unchecked it without any effect.
Old   September 9, 2013, 14:49
Bruno Santos
From your description, only the "Show Plane" option seems to fit the description, as shown in attachment. Look for the mouse pointer in the "Properties" tab.
File Type: jpg Screenshot from 2013-09-09 19:47:48.jpg (46.8 KB, 10 views)
Old   September 9, 2013, 15:49
Ehsan
Bruno still its grey
which files I send so that could have a look in paraview?thanks.
Old   September 9, 2013, 15:53
Bruno Santos
  1. Select the entry "WR_inviscid.foam".
  2. On the menu, choose: File -> Save Data
  3. Save as VTK file and only the current iteration.
  4. Compress the VTK file with bz2 or gzip.
  5. Then email me the compressed VTK file.
Old   September 9, 2013, 16:24
Ehsan
I saved it on x-axis line as vtk.
Old   September 9, 2013, 16:30
Bruno Santos
I think you're confusing the threads... this thread is about the problem with seeing the aspect or area in 2D or 3D.
Old   September 9, 2013, 17:13
Ehsan
Bruno you said me to save a VTK file,but its not possible without "plot over line",there isn't any VTK format if I want to use only "save data"
Old   September 9, 2013, 17:24
Bruno Santos
I forgot about the detail that the internal reader uses multi-block structures...
Apply the filter "Merge Blocks" to the "WR_inviscid.foam"; then with "MergeBlocks1" selected, save data to VTK.
Old   September 9, 2013, 17:32
Ehsan
I did it.bz2 has 3MB volume and I'll mail it(maybe takes long)
Old   September 9, 2013, 17:33
Bruno Santos
I won't be able to look at it today. Send it to me only tomorrow, when you have a better internet connection.
[General] Listing the inputs of a grouped dataset with a programmable python filter in Paraview NadineHS ParaView 3 December 12, 2021 14:54
[General] Include Timevalue in (Python) Calculator Operation weidatm ParaView 0 May 16, 2018 07:56
[General] Get data from Calculator filter in python script taalf ParaView 17 February 15, 2018 04:53
[General] Using variables defined in a Python script on a Paraview/Python Calculator gafxian87 ParaView 0 June 8, 2015 13:18
[OpenFOAM] Access to Python Calculator Tobi ParaView 1 September 9, 2014 06:32
