[OpenFOAM] Visualizing imported meshes
Old   November 5, 2013, 11:37
Question Visualizing imported meshes
sudo is on a distinguished road
Ok, so I am still a beginner at OF trying to figure how things work out. I imported 2 meshes with varying success:
1. From HyperMesh in .cas format, then imported via fluentMeshToFoam. Importing was successful, but could not visualize w/ paraFoam, used
> foamToVtk
> paraview
Opened the 0.vtk file and it worked like a charm!
2. From Star CCM+ 8.04, I imported the 2D mesh from the back step tutorial. ccm26ToFoam worked fine and updated the files in the polyMesh folder (all but blockMesh).
Now I tried to do exactly as I did before:
1. deleted the p, U 0-files.
2. foamToVtk (so that I can use paraview)
but I received the following error(s):
Build  : 2.2.2-9240f8b967db
Exec   : foamToVTK
Date   : Nov 05 2013
Time   : 09:18:47
Host   : "UbuntuAres"
PID    : 6301
Case   : /home/openfoam/OpenFOAM/openfoam-2.2.2/Third_Party_Downloads/ccm26ToFoam/cavity
nProcs : 1
Create time
Create mesh for time = 0
Deleting old VTK files in "/home/openfoam/OpenFOAM/openfoam-2.2.2/Third_Party_Downloads/ccm26ToFoam/cavity/VTK"
Time: 0
    volScalarFields            : cellId cellType
    Internal  : "/home/openfoam/OpenFOAM/openfoam-2.2.2/Third_Party_Downloads/ccm26ToFoam/cavity/VTK/cavity_0.vtk"
--> FOAM FATAL ERROR:
Serious problem: asked to split a face with < 3 vertices
    From function face::split(const face::splitMode, const pointField&, label&, label&, faceList&, faceList&)
    in file meshes/meshShapes/face/face.C at line 143.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::face::split(Foam::face::splitMode, Foam::Field<Foam::Vector<double> > const&, int&, int&, Foam::List<Foam::face>&, Foam::List<Foam::face>&) const at ??:?
#3  Foam::face::nTrianglesQuads(Foam::Field<Foam::Vector<double> > const&, int&, int&) const at ??:?
 at ??:?
 at ??:?
 at ??:?
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Aborted (core dumped)
So, any idea how to fix that? Thanks.
sudo is offline   Reply With Quote
Old   November 9, 2013, 15:23
Retired Super Moderator
Bruno Santos
Greetings sudo,
Well, the problem is that the mesh is far from perfect, which leads to foamToVTK not be able to split a strange looking cell.
You can try using the option "-poly", which preserves the structures of polyhedral cells, without splitting/decomposing them; but I'm guessing you'll get another similar problem sooner or later, since the mesh is not perfect.
As for not being able to open the mesh with paraFoam, I won't be able to help without seeing the complete error message.
Best regards,
Bruno
ccm+ foamtovtk paraview
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
Rotor-Stator with separate imported meshes jrrygg OpenFOAM Pre-Processing 4 October 29, 2012 09:42
[Netgen] keeping/changing dimensions in imported meshes bigred OpenFOAM Meshing & Mesh Conversion 2 September 28, 2009 03:38
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
[Technical] Using stitchmesh on imported gmsh meshes christian67 OpenFOAM Meshing & Mesh Conversion 0 November 26, 2005 04:22
