April 1, 2014, 09:49 |
PlotOverLine: boundary value ?
Francois Beaubert
Rep Power: 17 |
Hi all,
There is a behavior I find really annoying in some cases: it is the fact that after a plotOverLine boundary values (on patches) are not routinely used. For example it's not possible to have on the curve of a plotOverLine the value of zero for the velocity at a stationnary wall . Do you watch also this behavior? How can we fix it ? Thanks Francois |
April 1, 2014, 15:38 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Francois,
I've tested just now with ParaView 3.12.0 and 4.1.0, on OpenFOAM 2.2.x and 2.3.x respectively, using the tutorial "incompressible/icoFoam/cavity" as reference. And used both the internal reader (file extension ".foam") and the official reader (".OpenFOAM"). At first, I didn't have any problem what so ever. The values at the boundaries were represented without any problems. But them I remembered to move ever so slightly one of the ends of the sampling line and pufft... there it went out the door, the value at the boundary. Therefore, there are 2 issues at work here:
Best regards, Bruno
April 3, 2014, 03:34 |
Francois Beaubert
Rep Power: 17 |
Hi Bruno,
Thank you very much for your kind and helpful answer. What you described is exactly what I met and when playing a little on the positions of the ends point I can get the values at the boundaries. The most sensitive cases beings when the sampling point is not exactly in the same plane as sampling points that make up the face of the boundary. So apparently no systematic solution except to play on the positions of the end points especially if the surface of the patches are curved surfaces as it is the case for me. Any way thanks you very very much for your advices. Regards, François Last edited by francois; April 7, 2014 at 15:28. |
April 6, 2014, 14:10 |
Bruno Santos
Rep Power: 128 |
Hi François,
I forgot the other day to mention that there is another possibility, explained here: http://www.cfd-online.com/Forums/ope...tml#post476212 post #2 Best regards, Bruno |
April 7, 2014, 15:30 |
Francois Beaubert
Rep Power: 17 |
Thanks for the advice Bruno
Will try this method to see if I get better results Best regards François |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
