Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64 |
July 23, 2014, 04:29 |
Hassan Zarei
Hi Dear Foamers
I have OpenFOAM 2.2.0 installed on my OpenSUSE 12.2, now i want to install OpenFOAM 2.3.0 rpm pack.but after installing OpenFOAM-2.3.0-1.x86_64.rpm successfully, i encounter the following error when i want to install OpenFOAM-ParaView-4.1.0-1.x86_64.rpm: package OpenFOAM-ParaView-3.12.0-1.x86_64 (which is newer than OpenFOAM-ParaView-0.1.1-1.x86_64) is already installed could you please help me... thanks |
August 5, 2014, 13:05 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Hassan,
Sorry for the late reply. I don't know if you've managed to solve this issue already or not? If you haven't solved this yet, can you please confirm the error message you're getting? I ask this because the version indicated in the error message "ParaView-0.1.1" is really strange and it should indicate "ParaView-4.1.0". Best regards, Bruno |
paraview 4.1.0 |
[OpenFOAM] No eye icon when using ParaView with OpenFOAM | rmvega | ParaView | 0 | July 2, 2014 09:59 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
Pls help last problem to be solved for installing OPENfoam | daydayuper | OpenFOAM Installation | 5 | November 9, 2008 04:59 |
Problem installing OpenFOAM 141 | sachin | OpenFOAM Installation | 2 | February 22, 2008 10:20 |
