Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraview message
Old   December 19, 2014, 16:38
Exclamation paraview message
a_habib's Avatar
Ahmad Habib
a_habib is on a distinguished road
when I start the program it gives me this message
Application asked to unregister timer 0x69000013 which is not registered in this thread. Fix application
what is the solution
I'm using Ubuntu 12.04, OpenFoam 2.2.1
a_habib is offline   Reply With Quote
Old   December 21, 2014, 02:12
a_habib's Avatar
Ahmad Habib
????? no one
Old   January 16, 2015, 06:44
Fatih Ertinaz
fertinaz is on a distinguished road
how do you exactly start paraview?
paraFoam or using paraview executable in bin folder?
my first guess would be related to qt version you have.
fertinaz is offline   Reply With Quote
Old   January 16, 2015, 07:00
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
https://www.google.fr/search?q=appli...timer+paraview
http://www.openfoam.org/mantisbt/view.php?id=467
alexeym is offline   Reply With Quote
Old   January 21, 2015, 11:56
a_habib's Avatar
Ahmad Habib
I start paraview like this
paraview & case_name.foam
Old   January 22, 2015, 03:06
T. Chourushi
Tushar@cfd is on a distinguished road
Is your paraview opens? Try running only paraview command in terminal.
paraview
If the above command works well then convert your FOAM file to VTK using the following command in terminal:
foamToVTK
Open this VTK file in paraview. I think this will work.
Best Luck!
Tushar@cfd is offline   Reply With Quote
paraview 3.12
[OpenFOAM] Paraview client/server does not work with ParaView 5.0.1 snak ParaView 0 October 17, 2016 10:22
[General] Paraview Binary and OSPray plugin Prapanchnair ParaView 0 May 27, 2016 06:26
[OpenFOAM] Plot over line fails in ParaView mheinz ParaView 4 May 23, 2016 05:28
ParaView installation problem on Suse 11.4 victorz OpenFOAM Installation 4 February 6, 2012 17:26
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
