Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Surface Flow or Integrate Variables
Old   February 26, 2015, 23:20
Question Surface Flow or Integrate Variables
Elena
lenkri is on a distinguished road
Hello.
All my results (the values of temperature flow in mesh nodes) are obtained from OOFEM.
Now I need to calculate heat flow through the all surface of my 3d model. For this purpose I use filters of ParaView, such as Extract Surface->Surface Flow->Plot Selection Over Time. Should I plot Surface Flow or IST_TemperatureFlow(Magnitude)? What is the difference between these two calculated parameters? Maybe I wrong, and filter Integrate Variables is more appropriate instead of filter Surface Flow.
My second question is how to calculate heat flow through the separate surface (for example, top or bottom side of my model).
I’m looking forward to your help and advice. Thank you in advance for your response.
lenkri is offline   Reply With Quote
integrate variables, surface flow
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
[OpenFOAM] How to calculate the fluid flow through a surface lynx ParaView 4 January 20, 2016 11:58
[General] IntergateVariables filter. How to select variables to integrate? Antech ParaView 0 June 4, 2015 02:38
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
