December 20, 2007, 21:30 |
No geometry
weihong yao
Rep Power: 17 |
hi
when i do the Tutorials's case(cavity).when i type "paraFoam $FOAM RUN/tutorials/icoFoam cavity" ,the Paraview is appear,when i click "Accept".the Paraview is exit!And appear some erroras show below) FOAM FATAL IO ERROR:attempt to read beyond EOF File:././o/u::Value at Line 37 From Funtion ITstream::read(token$.t) in file db/IOstream/ITread.c at Line 70. I use the openfoam1.4.and the Paraview2.4.4.is it ok? how to fit the problem? |
December 20, 2007, 21:47 |
weihong yao
Rep Power: 17 |
when i type "paraFoam $FOAM RUN/tutorials/icoFoam cavity" the Paraview is appear but I see the "Time"
constant 0 I can not see 0.1 0.2 0.3 0.4 0.5 And i click the "ALL ON" the situayion did not change. what is the problem? |
December 20, 2007, 22:24 |
Can you see your case mesh usi
Marhamat Zeinali
Rep Power: 17 |
Can you see your case mesh using parFoam?
follow User guid step by step. And please don't repeat your question in different pages. |
December 20, 2007, 22:58 |
sorry about it.I can not see t
weihong yao
Rep Power: 17 |
sorry about it.I can not see the mess.I have said when I click "Accept",the Paraview was quit.And i get some errors.
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 21:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
