Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] No geometry
Old   December 20, 2007, 21:30
Default No geometry
weihong yao
ivanyao is on a distinguished road
hi
when i do the Tutorials's case(cavity).when i type "paraFoam $FOAM RUN/tutorials/icoFoam cavity" ,the Paraview is appear,when i click "Accept".the Paraview is exit!And appear some erroras show below)
FOAM FATAL IO ERROR:attempt to read beyond EOF
File:././o/u::Value at Line 37
From Funtion ITstream::read(token$.t) in file db/IOstream/ITread.c at Line 70.
I use the openfoam1.4.and the Paraview2.4.4.is it ok?
how to fit the problem?
ivanyao is offline   Reply With Quote
Old   December 20, 2007, 21:47
Default when i type "paraFoam $FOAM RU
weihong yao
when i type "paraFoam $FOAM RUN/tutorials/icoFoam cavity" the Paraview is appear but I see the "Time"
constant
0
I can not see
0.1
0.2
0.3
0.4
0.5
And i click the "ALL ON"
the situayion did not change.
what is the problem?
Old   December 20, 2007, 22:24
Default Can you see your case mesh usi
Marhamat Zeinali
marhamat is on a distinguished road
Can you see your case mesh using parFoam?
follow User guid step by step.
And please don't repeat your question in different pages.
marhamat is offline   Reply With Quote
Old   December 20, 2007, 22:58
Default sorry about it.I can not see t
weihong yao
sorry about it.I can not see the mess.I have said when I click "Accept",the Paraview was quit.And i get some errors.
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 02:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 21:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 03:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 13:49
