Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Error while postprocessing channelOodles tutorial in OpenFOAM 13
Old   April 6, 2006, 15:34
Default Error while postprocessing channelOodles tutorial in OpenFOAM 13
Alberto Passalacqua
While post-processing the channelOodles tutorial case in OpenFOAM 1.3, when I select a time step in ParaView and click on Accept, I get the following error message:
alberto@dimension4400:~/OpenFOAM/alberto-1.3/run/tutorials/channelOodles> paraFoam . channel395
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
--> FOAM FATAL ERROR : Not implemented
From function void CyclicPointPatchField<patchfield,>::evaluate()
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/CyclicPointPatchFie ld.C at line 187.
FOAM aborting
/home/alberto/OpenFOAM/linux/paraview-2.4.2/lib/paraview-2.4/paraview-real: symbol lookup error: /home/alberto/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libOpenFOAM.so: undefined symbol: cplus_demangle
The case can be postprocessed without problems using OpenFoam 1.2.
How can I solve the problem?
Thanks in advance,
Alberto
Alberto Passalacqua
Old   April 8, 2006, 08:26
Default can you report this as a bug?
Mattijs Janssens
mattijs is on a distinguished road
Two workarounds (not tested):
- use foamToVTK with -noPointValues
- change the cyclic patchFields temporarily to be e.g. fixedValue (and change the cyclicPolyPatch type in the polyMesh/boundary file accordingly)
mattijs is offline   Reply With Quote
Old   April 8, 2006, 12:59
Default Sure, I'll add it to the bug d
Alberto Passalacqua
Sure, I'll add it to the bug discussion forum.
Thanks. I'll try your suggestions immediatly.
Unfortunately I've just tried to install OpenFOAM 1.3 on our Rocks cluster and it's not running due to incompatibilities in libs.so.6 versions.
I tried to create a compatibility environment as explained by Novell in http://www.novell.com/coolsolutions/feature/11775.html but it doesn't work .
I hope to find a solution soon.
Best regards,
Alberto
Alberto Passalacqua
Old   April 12, 2006, 13:25
Default Indeed, I also have the same b
anne dejoan
anne is on a distinguished road
Indeed, I also have the same bug when using
paraFOAM on the channelOoles case and dowloading
the field at a time step.
Any solution instead of having to change all the
cyclic ?
Thanks
anne is offline   Reply With Quote
Old   April 13, 2006, 05:58
Default See http://www.cfd-online.c
Mattijs Janssens
See
http://www.cfd-online.com/cgi-bin/Op...=7286#POST7286
[FSI] HronTurek Tutorial OpenFoam extend: no flag movement roma-aeterna OpenFOAM CC Toolkits for Fluid-Structure Interaction 13 October 15, 2019 04:11
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial mörli OpenFOAM Running, Solving & CFD 0 April 9, 2019 11:50
OpenFOAM XiFoam Tutorial FPE Error Bish OpenFOAM 1 November 15, 2017 17:59
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
Tutorial Not Running In OpenFOAM H0T_S0UP OpenFOAM 2 January 20, 2015 16:58
