[OpenFOAM] Error while postprocessing channelOodles tutorial in OpenFOAM 13 |
April 6, 2006, 15:34 |
Alberto Passalacqua
Rep Power: 36 |
While post-processing the channelOodles tutorial case in OpenFOAM 1.3, when I select a time step in ParaView and click on Accept, I get the following error message:
alberto@dimension4400:~/OpenFOAM/alberto-1.3/run/tutorials/channelOodles> paraFoam . channel395 /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ --> FOAM FATAL ERROR : Not implemented From function void CyclicPointPatchField<patchfield,>::evaluate() in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/CyclicPointPatchFie ld.C at line 187. FOAM aborting /home/alberto/OpenFOAM/linux/paraview-2.4.2/lib/paraview-2.4/paraview-real: symbol lookup error: /home/alberto/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libOpenFOAM.so: undefined symbol: cplus_demangle The case can be postprocessed without problems using OpenFoam 1.2. How can I solve the problem? Thanks in advance, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 8, 2006, 08:26 |
can you report this as a bug?
Mattijs Janssens
Rep Power: 26 |
Two workarounds (not tested): - use foamToVTK with -noPointValues - change the cyclic patchFields temporarily to be e.g. fixedValue (and change the cyclicPolyPatch type in the polyMesh/boundary file accordingly) |
April 8, 2006, 12:59 |
Sure, I'll add it to the bug d
Alberto Passalacqua
Rep Power: 36 |
Sure, I'll add it to the bug discussion forum.
Thanks. I'll try your suggestions immediatly. Unfortunately I've just tried to install OpenFOAM 1.3 on our Rocks cluster and it's not running due to incompatibilities in libs.so.6 versions. I tried to create a compatibility environment as explained by Novell in http://www.novell.com/coolsolutions/feature/11775.html but it doesn't work . I hope to find a solution soon. Best regards, Alberto
April 12, 2006, 13:25 |
Indeed, I also have the same b
anne dejoan
Rep Power: 17 |
Indeed, I also have the same bug when using
paraFOAM on the channelOoles case and dowloading the field at a time step. Any solution instead of having to change all the cyclic ? Thanks |
April 13, 2006, 05:58 |
See
http://www.cfd-online.c
Mattijs Janssens
Rep Power: 26 |
[FSI] HronTurek Tutorial OpenFoam extend: no flag movement | roma-aeterna | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 13 | October 15, 2019 04:11 |
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial | mörli | OpenFOAM Running, Solving & CFD | 0 | April 9, 2019 11:50 |
OpenFOAM XiFoam Tutorial FPE Error | Bish | OpenFOAM | 1 | November 15, 2017 17:59 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
Tutorial Not Running In OpenFOAM | H0T_S0UP | OpenFOAM | 2 | January 20, 2015 16:58 |
