[OpenFOAM] Why dosnbt it work on paraview when inputing the results of the case tutorialsstr |
March 22, 2006, 09:12 |
dandes.Huang
Neather using ParaFoam<root><filename> nor transfering the results to VTK form the GUI do not have the parameters such as stress or dispplacement choosed to present。 sincerely hoping some one can help to resolve the disaster ! Really appreciate your helping , Thx ^^
March 22, 2006, 09:41 |
foamToVTK only converts scalar
Eugene de Villiers
Rep Power: 21 |
foamToVTK only converts scalar and vector fields. If you want your stresses to be converted you will first have to decompose then into vectors or scalar components.
March 22, 2006, 10:47 |
THX first . But it semms not t
dandes.Huang
THX first . But it semms not the point of this problem . I can't find the property of stree or displacement to display even i never convert the results to the VTK format . In other words , i use paraview in Linux system but still no effect . I guess if the stress analysis of segregated finite-element (by the case) is little different to finite-volume , or maybe the results(only sigmaxx,sigmayy,sigmaxy,U) aren't enough for paraview to present it . Or even the results of the analysis are in error . I wish what i explain above is clear for your thinking . Thx again ^^
March 22, 2006, 11:06 |
Run:
R
Eugene de Villiers
Rep Power: 21 |
Run:
R <root> <case> //calcs stresses and then Rcomponents <root> <case> //makes stress components and then foamToVTK <root> <case> I have no idea what displacement is in this context |
[OpenFOAM] How to view openfoam results in paraview | Marineboy | ParaView | 9 | June 19, 2019 21:16 |
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case | romant | ParaView | 3 | April 7, 2014 15:42 |
[OpenFOAM] parallel case with paraview | Ingenieur | ParaView | 2 | August 16, 2013 08:24 |
UDF to transfer results from one case to the next case | howhs | Fluent UDF and Scheme Programming | 4 | July 16, 2013 23:31 |
how to map results from steady state run to tranient case? | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2010 06:20 |
