October 13, 2009, 21:28 |
HELP with makeParaView
Allan Mabe
I have just revently installed OpenFOAM 1.6 and I was following the instructions for compiling paraView and I ran into a problem. The computer is telling me that the command 'makeParaView' is not valid and 'make ParaView' does not work either. I don't know how to get it to work.
I need help very soon |
October 14, 2009, 02:31 |
#2 | |
Mark Olesen
Rep Power: 40 |
which makeParaView echo $PATH Try changing 'cd $WM_THIRD_PARTY_DIR' (that's what the foam3rdParty alias does) and then running './makeParaView' from there. |
October 14, 2009, 11:31 |
Allan Mabe
I did that and then I have now encountered a problem with the './Allwmake' command. It gets through a lot of the compiling and then encounters errors and aborts the installation.
For the command 'INCLUDE' in the CMake file, it says that there are too many arguments and that it needs only 1 argument. I looked at the command line that it is having trouble with and there are several files that it inlcudes. How do I fix or get around this error? |
October 15, 2009, 02:16 |
#4 | |
Mark Olesen
Rep Power: 40 |
[OpenFOAM.org] OpenFOAM 5.0: makeParaView error: Could NOT find OpenGL | yaoyn | OpenFOAM Installation | 5 | March 26, 2018 16:32 |
Compiler error with makeParaView | zhang88 | OpenFOAM Installation | 2 | December 10, 2013 13:12 |
difficulty with paraview compiling | linch | OpenFOAM Installation | 10 | October 14, 2010 07:28 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
makeParaView not working | scottneh | OpenFOAM Installation | 2 | September 26, 2009 12:49 |
