Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Problem in calculating Gradient
Prev Previous Post   Next Post Next
Old   March 16, 2015, 06:38
Default Problem in calculating Gradient
Masaaki Shojima
masaaki is on a distinguished road
Dear specialists, and Dear friends,
I have problems in calculating "Gradient" of a scalar field in Paraview.
Paraview provides several methods to calculate the gradient of a certain scalar, such as
1. Gradient of Unstructured Dataset filter
2. Compute Delivatives filter
3. Phython calculation filter > gradient (scalar)
...and so on.
When I calculated the gradient of a certain scalar such as pressure, the results of paraview would be half compared to those of Ensight and SC/Tetra-post.
Take a look of the attached image, please.
I calculated of a flow in a cylinder using SC/Tetra solver. The results were exported in CGNS file and read in Ensight and Paraview.
Gradient (Pressure) was calculated and Z component of Grad (Pressure) was visualized on the surface.
SC/Tetra post and Ensight provided the same results. But Paraview made a different result. The computed gradient on the surface was half.
This phenomenon occurred in other settings. The values of Grad (velocity-x) or Grad (velocity-y) were also half in paraview compared to Ensight.
I also changed the solver (Frontflow red). But the computed gradient by Paraview was half of other software.
Why the computed gradient becomes half in Paraview ? ? ?
Please teach me, my friends.
Thanks a lot !
masaaki is offline   Reply With Quote
ensight, gradient at boundary, paraview
Smagorinsky Problem - LES - Internal pipe flow gu1 OpenFOAM Running, Solving & CFD 2 December 29, 2017 17:54
pressure gradient of a 2D periodic flow problem Honey FLUENT 1 October 17, 2012 06:06
pressure gradient of a 2D periodic flow problem Honey FLUENT 0 September 19, 2012 03:21
Calculating gradient only at patchInternalField 7islands OpenFOAM Running, Solving & CFD 6 March 20, 2011 21:06
problem with gradient as source term in coupled equations Cyp OpenFOAM Programming & Development 0 August 16, 2010 13:12
