Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Water surface profile in OpenFoam dambreak case
Old   January 28, 2012, 23:59
Default Water surface profile in OpenFoam dambreak case
abdikerim kurbanaliev
kerim is on a distinguished road
Dear all!
Can someone help me with my problem? I need to build 3D water surface profile for OpenFoam dambreak case. The picture should be like as in attached file. How can I do that? Any help will be highly appreciated.
Thanks in advance.
kerim is offline   Reply With Quote
Old   January 29, 2012, 13:26
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Hi karim.
Assuming you have already run the case, you need to open paraview, load the case, make shure that the VoF is loaded (alpha) and then create a contour of 0,5 alpha. Make shure that it is visualized as a surface and there you go.
Hope it helps.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   February 9, 2012, 18:21
Hi Vieri,
Thank you for your information. I followed to your suggestion but it doesn’t help me. Please see the pictures I received. There are two of them: the first is the alpha surface plot at the end time and the other is the counter plot -isosurface of alpha value 0.5 at the end time. It is not what I am looking for. Any other idea?
Kerim
Old   February 20, 2012, 03:52
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
You should try the "clip" filter for alpha with a value of 0.5.
Mattia
demichie is offline   Reply With Quote
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFoam restarting simulation, stops at first Time loop syntex OpenFOAM Running, Solving & CFD 4 April 5, 2019 11:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 alsdia OpenFOAM Running, Solving & CFD 3 October 22, 2012 11:25
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
