Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallHeatFlux utility and chtMultiRegionFoam solver
Old   October 5, 2011, 06:29
Default wallHeatFlux utility and chtMultiRegionFoam solver
vladimir krejci
Lada is on a distinguished road
I have run into problem using wallHeatFlux utility to obtain patches heat fluxes when applied to chtMultiRegionFoam solver. The message I am getting is:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/lada/OpenFOAM/lada-2.0.0/run/BALKON/balkon_svisle_1/constant/thermophysicalProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
Is there any way to solve this problem except for writing my own wallHeatFlux utility?
Lada is offline   Reply With Quote
Old   June 7, 2012, 08:10
Tuxeedo's Avatar
Hauke
Tuxeedo is on a distinguished road
Hey Vladimir,
did you find a Solution to your problem?
Tuxeedo is offline   Reply With Quote
Old   June 7, 2012, 08:50
vladimir krejci
I had to modify patchIntegrate or patchAverage or combine both of them to define a utility that would give me the heat fluxes. My model was a rather simple one (essentially heat conduction only) consisting of multiple solids with defined heat transfer coefficient and temperature at the outer surface.
And I wasn't able to get the fluxes via the wallHeatFlux utility.
Old   June 7, 2012, 09:02
Tuxeedo's Avatar
Hauke
Thanks for your Reply.
Unfortunately i'm stuck on a coorporate installation where compiling self made tools is an enormous hassle.
I am surprised, that it is difficult to obtain wall heat Flux in a very simple incompressible steady state fluid solid system...
Old   June 7, 2012, 09:46
vladimir krejci
Sadly, I'm not too skilled at modifying or writing my own codes as that one was my first one. I have slightly diverted my attention off the openFoam. I've tried looking up whether wallHeatFlux is applied within tutorials but no success. I'm sorry but I can't help you much.
I suppose asking you 'have you searched the forum here for anything related to your application' is rather silly.
chtmultiregionfoam, wallheatflux
Problem with running chtMultiRegionFoam after using setSet utility Victor OpenFOAM 12 March 24, 2023 00:01
Is the sample utility compatible with chtMultiRegionFoam mirko OpenFOAM Post-Processing 4 February 15, 2016 07:28
