Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
To calculate wall shear stress in of210 for les simulation
Like Tree25Likes
Old   December 11, 2012, 03:16
Dejan Morar
morard is on a distinguished road
Hi Nati,
yes, there are 3 components, in x, y and z direction. If you want to separate them, you can use foamCalc:
foamCalc components wallShearStress
this gives you: wallShearStressx, wallShearStressy and wallShearStressz.
For the lift and drag forces I can't help you much. Try to modify one of the post processing utilities to fit your case. It might help if you take a look into the folder /applications/test. You can find a lot of examples there.
Regards,
Dejan
nati and chengyu like this.
morard is offline   Reply With Quote
Old   December 11, 2012, 03:52
nati is on a distinguished road
Hi Morard,
thank you for your help.
Excuse me, Do you know, how to calculate turbulent dissipation energy in each point?
Regards,
Nati
Originally Posted by morard View Post
Hi Nati,
Regards,
Dejan
nati is offline   Reply With Quote
Old   December 12, 2012, 18:58
Qiang Zhou
michael1023 is on a distinguished road
What`s the difference between devReff and devBeff? In my case, the wallShearStressLES which include devReff can also be complied. Thank you.
michael1023 is offline   Reply With Quote
Old   December 12, 2012, 19:05
Qiang Zhou
Originally Posted by wikstrom View Post
Reff is the effective (viscous+turbulent) stress tensor (calculated by the turbulence model). For laminar flow (or y-plus low) this would be more or less nu*grad(U).
Hi Wikstrom. What is the difference between the Reff and friction forces on a surface by a turbulence model, such as simulating a flow past over a circular cylinder by LES? Thank you.
Old   December 13, 2012, 06:37
Niklas Wikstrom
wikstrom is on a distinguished road
Look at the wallShearStress.C (applications/utilities/postProcessing/wall/wallShearStress), e.g. in the the calcIncompressible() function.
Reff is a tensor, whereas the wall shear stress is the vector produced by the scalar product of 'wall face unit normal' and the Reff tensor. To get the friction force, then, you would need to surface integrate the wall shear stress.
wikstrom is offline   Reply With Quote
Old   December 18, 2012, 01:28
Qiang Zhou
Thanks for your quite reply. I have read the code of wallShearStress.C. From what your said, I think that the wall shear stress has the same meaning with the friction force coefficient for three directions (x,y,z). Is it right?
In addition, Reff is a tensor for RAS model and how to calculate the tensor in LES model?
Old   December 18, 2012, 03:15
sqing
Sunxing is on a distinguished road
Hi Niklas,
I think that for incompressible flow, the wallShearStress just give us the tau_w/rho, i.e nu*grad(U) , not mu*grad(U). Am i right?
regards,
Sunxing
Sunxing is offline   Reply With Quote
Old   June 24, 2013, 10:43
Smile it error for "essential value entry not provided" and my boundary is symmtryPlane
  #28
Du An
duan2013xjtu is on a distinguished road
Hi, friends! When I run 'wallShearStressLES', it exit:
--> FOAM FATAL IO ERROR:
file: /home/cylinder/3.800000e+02/phi::boundaryField::sides1_half0 from line 425805 to line 425805.
From function fvsPatchField<Type>::fvsPatchField
const fvPatch& p,
const DimensionedField<Type, surfaceMesh>& iF,
const dictionary& dict
in file lnInclude/fvsPatchField.C at line 110.
FOAM exiting
my boundary is symmtryPlane. Do I need to change the symmetryPlane to patch?
best wishes,
Linda
Hi Nati,
Regards,
Dejan
duan2013xjtu is offline   Reply With Quote
Old   December 27, 2013, 20:21
Default Code
  #29
Oscar Ochoa
Gatoscar is on a distinguished road
Hello everyone:
Despite the fact that this is an old thread, I attach the code that I modified following the instructions posted here. I verified the results with one case of incompressible fluid in a pipe with dynamicSmagorinsky LES turbulence model. This is for OF2.1.1.
I hope this will be helpful for someone.
Regards
wyldckat, tiam, Shahr and 2 others like this.
Gatoscar is offline   Reply With Quote
Old   December 28, 2013, 12:44
Retired Super Moderator
Bruno Santos
Greetings Oscar,
Many thanks for sharing! Can I convince you to add this to openfoamwiki.net?
You can follow the instructions at this page: http://openfoamwiki.net/index.php/Extend-bazaar
Or follow the examples on this page: http://openfoamwiki.net/index.php/Main_ContribUtilities
Best regards,
Bruno
Gatoscar likes this.
Old   January 10, 2014, 16:27
Oscar Ochoa
Hello Bruno
Sorry for the late response. I looked the two links you sent, and I'm convinced to upload the code of the wallShearStressLES, however, I'm gonna make more tests to the code to be completly sure that it works in the right way.
Thanks for the information about the foam-extend and OpenFOAM community.
Regards
wyldckat and vishwakarma like this.
Old   May 11, 2014, 12:28
ArathoN
ArathoN is on a distinguished road
I tried building this on OF 2.3 but it gives me this error:
/opt/openfoam230/src/turbulenceModels/compressible/LES/LESModel/LESModel.H:150:34: note: no known conversion for argument 4 from ‘Foam::basicThermo’ to ‘const Foam::fluidThermo&’
make: *** [Make/linux64GccDPOpt/wallShearStressLES.o] Errore 1
How can i solve it?
ArathoN is offline   Reply With Quote
Old   May 15, 2014, 08:14
Hans Barósz
HanSolo123 is on a distinguished road
Same problem here. Please let me know when you solved it.
HanSolo123 is offline   Reply With Quote
Old   June 2, 2014, 12:26
Shahr is on a distinguished road
How can i solve it?
Well, obviously you should replace the basicThermo to fluidThermo in the source code and header file. It will be fixed.
Shahr is offline   Reply With Quote
Old   June 22, 2014, 13:58
Bruno Santos
Greetings to all!
I've done a quick adaptation of the source code by Oscar Ochoa to OpenFOAM 2.2.x and 2.3.x.
It's currently provided here: https://github.com/wyldckat/wallShearStressLES
Download and installation instructions are given on that page.
Best regards,
Bruno
caduqued, Elham and Shahr like this.
Old   October 13, 2014, 21:46
Huang Xianbei
huangxianbei is on a distinguished road
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Hi,Bruno:
I have a question about the difference between wallShearStress calculated by the code and by the wallGradU. As in the definition, skin-friction coefficient is Cf = tau_wall/(0.5*rho*U^2), and tau_wall = rho*nu*GradU, while in wallShearStress, the wallShearStress is calculated by n_wallnormal &Beff, this doesn't contain rho, right? I compared the wallShearStress calculated by the 2 ways, however, I get quite different values.
Here, calculated by wallShearStressLES and wallGradU are both contained in the .tar
result.tar.gz
The value is of almost 100 times deviation! (The fluid is gas, with rho =1.25kg/m^3 and nu = 1.45e-5 m^2/s) What's wrong with it?
Best regards
Xianbei
huangxianbei is offline   Reply With Quote
Old   October 18, 2014, 15:26
Bruno Santos
Hi Xianbei,
If you had looked a bit more about this, specially look for posts where I mentioned "wallShearStress"... with Google, I can find with this:
site:www.cfd-online.com/Forums "wyldckat" "wallShearStress"
Mmm... a lot of threads... OK, the one where I pretty much answer your questions is in this post: http://www.cfd-online.com/Forums/ope...tml#post509408 post #6
Best regards,
Bruno
Old   October 18, 2014, 21:45
Huang Xianbei
Hi Xianbei,
Best regards,
Bruno
Hi,Bruno:
Thank you for your reply. From the link, I get to know the two ways to calculate tau, I use the second formula as you quoted, also, if I multiply wallShearStress with rho, they are still not the same I'll check it again.
Xianbei
Old   October 19, 2014, 04:31
Bruno Santos
Hi Xianbei,
I think that something very wrong is going on in your simulation. My guess is that the y+ values are way above 300, which results in a bad calculation by wallShearStress and/or wallGradU.
If you can provide more details about your case, it will make it considerably easier to help diagnose the problem. The main details that come t mind as being important:
  1. Is the simulation done with compressible or incompressible modelling?
  2. Regarding turbulence model: Laminar, RAS or LES?
  3. What are the inlet flow speeds and the flow speeds near the wall (the cell closest to the wall) and the sizes of the cells closest to the wall?
Best regards,
Bruno
Old   October 19, 2014, 06:51
Huang Xianbei
Hi Xianbei,
Best regards,
Bruno
Hi,Bruno
My case is a 90 bend duct with an aspect ratio of 6. Smagorinsky model is used with mean y+ <4, it's incompressible.
The inlet condition is obtain by interpolate the experimental velocity, and then mapped to the grid points.
The mesh's max aspect ratio is <700, which is OK when doing the checkMesh
Here is the comparison of the two results at inletcompare.ods.tar.gz
The first 7 rows of data are obtained using sample line, the 1st is distance, and following are the wallGradU vector and wallShearStress vector, each has 3 components. The x direction is the studied direction
Xianbei
Measuring wall shear stress in bend pipe liguifan OpenFOAM 70 December 9, 2015 03:49
What is wall shear stress and shear strain rate? warlocklw Main CFD Forum 2 May 21, 2012 06:16
wall shear stress lingo FLUENT 2 June 2, 2003 03:40
Specifying shear stress on wall in 5.5.1 michael rasmussen CFX 1 May 19, 2003 09:49
plotting wall shear stress Ellen FLUENT 1 April 5, 2002 22:50
