How to calculate torque from the simulation result |
November 8, 2012, 08:19 |
Hi Foamers,
I want to calculate torque from the simulation, can you guys help me? I have used MRFSimpleFoam for my simulation. The fan RPM is 750. please give me some idea. Thanks and regards, Sivakumar |
November 15, 2012, 09:35 |
Laurent B
Rep Power: 16 |
February 11, 2013, 06:41 |
Hi Guys,
After a long struggle, I came to the conclusion regarding torque. To calculate torque we need to use this function in the controlDict file. functions ( forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches (wallBlade); // pname p; // Uname U; rhoName rhoInf; log true; rhoInf 1.205; CofR (0 0 0); } ); results will be as follows: forces(pressure, viscous)((2162.2 -313.192 35.8823) (12.5865 3.1166 3.97532)) moment(pressure, viscous)((1162.4 6862.37 100.944) (-12.5067 35.4299 -50.9462)) now the the output pressure force is not exact pressure (unit m2/s2) so to get exact torque = obtained Torque (moment) / density Thanks, Sivakumar |
February 15, 2013, 05:04 |
Laurent B
Rep Power: 16 |
Does somebody can explain in details how to calculate torque with "forces" library data ? I try to compare experimental and simulation results but there is a big difference. I calculate the torque as follow : Torque = |moment(pressure) + moment(viscous)| and i obtain twice the experimental value... Thanks Laurent |
February 15, 2013, 06:08 |
hi,
Which solver you are using? for any simpleFoam you need to divide it with the density what you are using. Thanks, Sivakumar |
February 15, 2013, 06:24 |
Laurent B
Rep Power: 16 |
I'm using MRFSimpleFoam. The density is 1300 kg/m3. If i divide by 1300 the difference is bigger...
February 15, 2013, 06:36 |
hi,
What kind of simulation you are doing, I am also using MRFSimpleFoam for axial flow fan. In my case MRFSimpleFoam torque results keep on changing for each case Actually, I tried two cases one is with passage (suction side and pressure side of the fan) secondly two blade and quarter of the cylinder see the fig. for passage case I am getting 45 N-m (it should be 70-80 N-m) for 2 blade case I am getting 80 N-m I am totally confused, is there any problem with MRFSimpleFoam or in my settings. I am totally gone. Thanks, Sivakumar Last edited by sivakumar; February 20, 2013 at 05:57. |
February 20, 2013, 06:09 |
Hi Guys and Laurentb,
I got the right way to calculate torque. I was doing some wrong calculation, that is why my results were wrong. now I got the right results, with 2% error. To Laurentb, I am sorry man, I think I have miss guided you. Actually we need to multiply the pressure with density to get the exact pressure. to calculate torque: take the z component of the pressure force and viscous. torque = F*r F = ((P *A) *density+ tau *A) A --> area of the patch which you want to calculate torque. I hope it is clear now Thanks, Sivakumar |
February 22, 2013, 09:10 |
#9 |
Laurent B
Rep Power: 16 |
Finally the torque computed by the forces library fits my experimental data with 10% error. My error comes from that i turn off the turbulence in RASProperties file for laminar flow conditions. If i turn on the turbulence option the force computation works well. Laurent |
April 9, 2013, 11:49 |
direction
#10 |
Baek, Donghae
Rep Power: 13 |
Hi all
I have something to ask. My case is 2D on x-y plane. Object look like airfoil and it is in wind tunnel. I obtain moment using force function added controldic file. Center of moment is z-axis. From result, moment has minus value. In this case, Is object rotated to clockwise or countclockwise?? |
May 6, 2013, 20:15 |
#11 | |
Dongyue Li
Rep Power: 17 |
Thats cool,Thanks very much.But I still have some problems. 1.How can I get the area of my patch? cuz its not a regular geometry. 2.If my impeller is rotating around y axiz.Should I pick the y component forces? 3.I have many impellers,How can I get the sum torque? 4.As we know,torque is F*radius, is this radius the max radius? 5.I am using MRFInterFoam, and I add this code into controldict. Code:
outputControl timeStep; outputInterval 1000; patches (intermigOpposite1); // pname p; // Uname U; rhoName rhoInf; log true; rhoInf 1000; CofR (0 0 0); } and I get the forces: Code:
forces output: forces(pressure,viscous)((-0.111013 9.4727 -0.09283),(0.00142333 -0.00100197 0.0121232)) moment(pressure,viscous)((-0.0196299 0.941766 0.19644),(0.00167602 0.0451228 0.000146112)) forces output: forces(pressure,viscous)((0.447146 12.7018 -0.170442),(-0.00129838 0.00185303 -0.00024443)) moment(pressure,viscous)((-0.0262434 0.928373 -0.127495),(1.8784e-05 0.0418585 0.000395807)) forces output: forces(pressure,viscous)((-0.0942824 4.63998 0.16988),(-0.00217494 -0.0359383 0.00219822)) moment(pressure,viscous)((0.0744167 1.1975 0.0769798),(0.00104654 0.0454346 0.00164999)) forces output: forces(pressure,viscous)((-0.226807 5.13595 -0.159452),(-0.0119485 -0.0779935 -0.00055085)) moment(pressure,viscous)((0.015837 1.36635 0.137174),(4.43451e-05 0.0472514 0.00681036)) forces output: forces(pressure,viscous)((0.300891 1.99927 0.0561256),(-0.00293573 0.00419335 0.000610194)) moment(pressure,viscous)((0.0233319 9.04241e-06 -0.05736),(0.000348815 0.000324186 0.000962111)) If I want to calculate,for example the first one. Force=(9.4727-0.0010017)*0.033555(my patch area)=0.3178n torque=0.3178*0.145(radius)=0.046Nm. Well, 0.046Nm is too small. There are many problems,Thanks again for your patience. Regards. Last edited by sharonyue; May 6, 2013 at 22:01. |
May 7, 2013, 08:33 |
#12 |
To calculate torque, just add the components (moment and viscous) which belongs to the axis of rotation. You no need to think of the area. In your case for the first output moment about y axis: y component of moment + viscous = 0.941766+0.0451228 If you get wrong torque, check your settings and blade angle. if your torque is small, how small it is? what is the experimental torque value? Thanks, Sivakumar |
May 7, 2013, 09:25 |
#13 | |
Dongyue Li
Rep Power: 17 |
If I add them all.and is this the torque? y component of moment + viscous = 0.941766+0.0451228 +0.928373 +0.0418585 +.....=4.6 Well , my experiment is a little different with my CFD case. but the torque should not differ much. if 4.6's unit is Nm, I think its normal. But in you last post, torque = F*r F = ((P *A) *density+ tau *A) A --> area of the patch which you want to calculate torque. Why is this using area? Anyway,you give me lots of hints,Thanks very much!! |
May 8, 2013, 03:39 |
#14 |
In the previous post I used force to calculate torque, so OF out put is interns of pressure force and viscous force. Pressure = F/A, so I used area. but, in your case just add the Y component of the pressure moment and viscous moment (this is the normal way). how many % error you are getting in torque? how good is your results with experimental results? Thanks, Sivakumar |
May 8, 2013, 23:36 |
#15 | |
Dongyue Li
Rep Power: 17 |
My experiment is a little different with my case,so I cannot make a comparision between them.But it should not differ much. If my case's torque is about 4 Nm. its normal. If its below 1 or 2Nm its not normal. And in my experiment, its two phase.Thats a gas-liquid mixer.Now I dont know how to calculate two phase's torque in FOAM.So... Well,looks like there are two ways calculating torque,1.use the forces to calculate which would need to know the area.2.use the moment just add them all.But in my case I think the first method is not working... |
May 14, 2013, 02:48 |
#16 | |
Dongyue Li
Rep Power: 17 |
Recently I use simpleFoam to make a test with the paper.There is only one patch in my rotating zone.I get the force like this: Code:
forces output: forces(pressure,viscous)((-2.76427e-06 -2.02655e-05 1.45751e-06),(-1.75831e-08 -9.23311e-08 1.98527e-08)) moment(pressure,viscous)((8.64124e-08 -0.00012881 2.0096e-07),(7.20421e-10 -8.69029e-07 1.63561e-09)) and my power number is 4.04e-3/(1000(density)*5^3*(0.0957diameter)^5)=4.03e-3 which is too small. In paper the power number is 4-5.which is one thousand times bigger.Do you know why.please.. Code:
forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches (impeller); // pname p; // Uname U; rhoName rhoInf; log true; rhoInf 1; CofR (0 0 0); } |
May 27, 2013, 16:42 |
#17 | |
Rep Power: 13 |
hi dear sivakumar i had simulated a wind turbine using fluent and i have problem with big amounts of torques in fluent.i don't know what to do exactly to get the exact torque amount. you had mentioned some formula in these posts but i don't know how to calculate the suitable area and totally what to do would you plz help me??? |
January 29, 2015, 05:38 |
#18 |
Dongyue Li
Rep Power: 17 |
Update,
Oh, time flies... I think I figure it out, put it simple, if we want calculate the torque on the blade, this is quite simple, please see the output below: Code:
forces forces output: sum of forces: pressure : (70.3478 2.53417 -0.129928) viscous : (-8.35929e-07 -3.77215e-07 -9.01343e-07) porous : (0 0 0) sum of moments: pressure : (-0.01138 -0.00344619 -9.2415) viscous : (-8.14101e-08 -1.81033e-08 7.56807e-08) porous : (0 0 0) power = 2 * 3.14 * rps * torque By this, I got almost the rite power with experiment. |
January 6, 2017, 03:00 |
#19 | |
yusiang
i am currently working on a propeller and looking for the torque acting on the blade. Base on the force.dat file , the torque i got from pressure moment is 4.124e-04 . is it = 0.0004124Nm? i suspect there is something wrong with this torque as the value is very small. |
November 17, 2018, 10:23 |
Calculation of thrust and torque for propeller
#20 |
sajad alimardani
Rep Power: 8 |
hi Brothers and sisters
I saw a dream -Dream no it is a nightmare- I am in the middle of a vortex. I'm turning around.I will not enter or leave. It seemed as if I stuck at the time I asked my question several times but answer...if If you see that greet me AMI-pimpledymfoam - propeller can you tell me how i Calculation of thrust and torque for propeller with preview??or other way if you can please help me. tanx s.alimardan Last edited by sajjjad; November 17, 2018 at 23:23. |
Torque of wind turbine simulation | caohan | FLUENT | 8 | August 11, 2014 23:01 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 09:32 |
How calculate simulation duration - CFX Solver | eRzBeNgEl | CFX | 3 | January 24, 2011 16:35 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 06:19 |
