OpenFOAM sample patch
Old   December 5, 2012, 03:47
Default OpenFOAM sample patch
Kentin cal
Kentin is on a distinguished road
Hi FOAMers,
I d like to know if someone has already succeeded to isolate a patch and sample values on it from the intersection with a plane, defined by basePoint and normalVector.
My problem is I have too many patches, so when i want to sample values from intersection of a specific patch and a plane, several patches are sampled.
Thanks for your help,
Kentin
Kentin is offline   Reply With Quote
Old   June 25, 2013, 06:01
Florian
Horus is on a distinguished road
Sorry, no real reply, but could you post your setup how you tried to sample patch - plane intersection?
Horus is offline   Reply With Quote
Old   September 24, 2013, 10:15
Disabled
anon_e is on a distinguished road
I had the same problem. I would like to sample my geometry at several distances from Inlet. I run the sample utilitiy some more times and changed sampleDict inbetween for the new points. I wrote an Allrun skript, which opens sampleDict and runs sample utility to advance handling ;-)
So it was not really your problem. But i had no problems with the surfaces.
So did you already try patchAverage utility? It gives averaged values for a patch.
anon_e is offline   Reply With Quote
openfoam, patch, sample
Windows 64-bit with Native MPI patch for OpenFOAM 1.6.x gocarts OpenFOAM Announcements from Other Sources 4 October 4, 2010 08:56
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
